It is currently Mon Oct 26, 2026 12:16 pm
Post Posted: Thu Dec 22, 2016 6:29 am
Hi guys got some sierra stuff for sale, see below.
Wide Track diffs - $300
Front: bare housing, axles and CV's. swap in your own diff centre and swivel hubs.
Rear: housing, rear axles and brakes only. Swap in your diff centre.
Sierra 1.3 distributor and cap, cap and rotor are reasonably new - $30
Targa bar pillar in grey, needs a paint - $80
Suzuki swift steering wheel - $20
6x Wide track metal flares - $75
Theres a complete set of straight black ones, holes in underside from flexi flares + 2 blue ones which are a little dented
1x heater box with core and blower - $30
Stock clutch cable, good condition - $20
Stock manual steering box, low km - $50
G16b long block - suspected cracked head - $50
1.3 fuel pump, used - $20
4x 1" wheel spacers (KPD 4x4 brand) - $100
Front door glass, both side available - $15each'
Front shocks - gabriel 11481 - 300mm closed, 500mm open - suit small bumstop spacer, used - $30
4 point roll bar made from 40nb pipe - suits tub and bolts to top of wheel tubs - $50
Located in Mount Waverley, can post smaller less fragile items
Post Posted: Wed Dec 28, 2016 6:36 am
bump
Post Posted: Mon Jan 30, 2017 6:10 pm
more items added, see top post
Post Posted: Mon Jan 30, 2017 7:03 pm
Best check with Luigi if he is interested in the the housings, post tech day.
Post Posted: Mon Jan 30, 2017 7:35 pm
Cool I'll do that. He'd just need a widetrack tie rod/drag link and he'd be sorted.
Vehicle: SJ51T
Post Posted: Mon Jan 30, 2017 9:15 pm
Does a wt hsg conversion need the wt toe rod and drag link?
Humble beginnings
Post Posted: Tue Jan 31, 2017 7:29 am
yep the drag link and tie rod are longer, the knuckles are no different so the tie rod is longer to compensate for the extra length of the housing.
Vehicle: SJ51T
Post Posted: Tue Jan 31, 2017 1:18 pm
lucky, i saved mine from my WT but totally oblivious to their future use
Humble beginnings
Vehicle: Suzuki Sierra Ute
Post Posted: Thu Mar 16, 2017 8:32 pm
Diffs still for sale?
Sent from my iPhone using Tapatalk Pro
Vehicle: lj50 soft top76
Post Posted: Sun Mar 19, 2017 9:46 am
do you still have the wheel spacers?
Post Posted: Sun Mar 19, 2017 10:25 am
What is the swift steering wheel like? And pics of the cage?
back in a built sierra!
Post Posted: Wed Apr 05, 2017 3:51 pm
Still got the flairs??
Post Posted: Thu Apr 06, 2017 6:25 pm
Still keen on steering wheel and pics of cage too.....
Users browsing this forum: No registered users and 71 guests
