It is currently Sat Oct 31, 2026 7:04 am
Vehicle: suzuki swift
Post Posted: Fri Apr 28, 2017 1:42 pm
Item Description: SUZUKI ENGINE - TOYOTA TRANSMISSION ADAPTER
Price: $250
Contact Details: PM
The “RingR”™ is a billet aluminium adapter that bolts in-between the Suzuki 1.6 litre 4x4 bellhousing and Toyota 4 cylinder W56 5 speed manual transmissions.
Precision machined from solid billet 6061-T6 aircraft quality aluminium, and supplied with premium Grade 5+ hardware, the “RingR”™ setup affords much greater strength and durability to your driveline, as well as numerous gearing options to get that KILLER CRAWL RATIO you desire!!
The “RingR”™ gives you the advantage of a stronger transmission and t-case(s), along with the ability to increase crawl ratios up to 555 to 1 !!. Slight modifications are needed for the clutch and throw out bearing.
Also included is the
The “Lucky 13”™. This adapter allows you to mate the Suzuki 1.3L engine to the Suzuki 1.6L 4x4 bellhousing.
Missing the bolts tho.
The Whole lot cost me $480
Users browsing this forum: No registered users and 49 guests
