| RingR & Lucky 13 http://auszookers.com/forum/viewtopic.php?f=7&t=54189 |
| Author: | astroleo_1976 [ Fri Apr 28, 2017 1:42 pm ] |
| Post subject: | RingR & Lucky 13 |
Item Description: SUZUKI ENGINE - TOYOTA TRANSMISSION ADAPTER Location: Melbourne Price: $250 Contact Details: PM The “RingR”™ is a billet aluminium adapter that bolts in-between the Suzuki 1.6 litre 4x4 bellhousing and Toyota 4 cylinder W56 5 speed manual transmissions. Precision machined from solid billet 6061-T6 aircraft quality aluminium, and supplied with premium Grade 5+ hardware, the “RingR”™ setup affords much greater strength and durability to your driveline, as well as numerous gearing options to get that KILLER CRAWL RATIO you desire!! The “RingR”™ gives you the advantage of a stronger transmission and t-case(s), along with the ability to increase crawl ratios up to 555 to 1 !!. Slight modifications are needed for the clutch and throw out bearing. Also included is the The “Lucky 13”™. This adapter allows you to mate the Suzuki 1.3L engine to the Suzuki 1.6L 4x4 bellhousing. Missing the bolts tho. The Whole lot cost me $480 |
