Joined: Wed May 11, 2011 3:13 am Posts: 645 Location: Brisbane
Vehicle: On the lookout
Posted: Thu Jul 06, 2017 1:06 pm
Body lift. Prevously installed on my 98 GV. Pick up only since I can't be bothered to post. Poly blocks and all the bolts, some special bolts you'll need.
Only issue with it, it Came with a 1 inch steering column extension. As you can imagine thats about 1 inch too short for a 2inch lift. There a fella local can likely knock up a 2inch copy pretty cheap I can give you his card or you can figure an alternative. I can offer detailed advice on what you have got to do to cut, extend or modify to install the kit also when you collect if you need helpz.
Users browsing this forum: No registered users and 19 guests
