Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
gbjim
Vehicle: jimny
 Posted: Fri Oct 27, 2017 5:44 pm |
Guaging interest in original Japanese market JB23 hood scoops 1999 - 2012. These can easily be made to fit Australian delivery Jimny's by a half competent diy'er. The bracing is the same and has the fitting screw holes already in the bracing in the Australian delivery bonnets. Cost would be $140 + postage. (These are used items from Japan in good condition). (These do not effect water into engine bay as the front grille itself is open!) Attachment: JDM hood scoop.jpg
gbjim
Vehicle: jimny
 Posted: Fri Oct 27, 2017 5:46 pm |
Addition of postage would only be the postage for domestic delivery within Australia, (you can pick up if your in Brisbane)
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Sun Oct 29, 2017 3:35 pm |
[quote="gbjim”] (These do not effect water into engine bay as the front grille itself is open!)[/quote]
What does this mean?
gbjim
Vehicle: jimny
 Posted: Mon Oct 30, 2017 9:08 pm |
Some people have stated that fitting a functional scoop would allow water into the engine bay, I'm just pointing out that water would be entering long bfore it gets to the scoop opening through the grille vents
Gwagensteve
 Posted: Wed Nov 01, 2017 7:01 am |
That’s false. When fording, the water level inside the engine bay stays relatively low, even if water is pushed over the bonnet. However, with a hole in the bonnet the water that flows up the bonnet lands on the coil packs. Don’t believe me? Conduct this thought experiment. Imagine driving through water with no bonnet on. Are you claiming the engine in a car with no bonnet doesn’t get any wetter than a car with a bonnet fitted?
The redundant scoop fitted to the local model jimny is blanked off to prevent this problem. (Because without an intercooler under the scoop it’s not functional)
By all means fit one of these if you like like them, and good luck with the sale- I’m sure there is a market, but the claim they don’t introduce more water into the engine bay is demonstrably false.
gbjim
Vehicle: jimny
 Posted: Fri Nov 03, 2017 11:00 pm |
Yeah I get it as the ac condensor and radiator would create an obstruction to the water flow
Page 1 of 1
[ 6 posts ] |
