It is currently Sat Oct 31, 2026 7:59 pm
Post Posted: Sun Aug 26, 2018 10:25 pm
1. Selling the diffs as they have come out of my lwb.
rear is complete hub to hub, spring bush to shackles.
front is only a housing and center but with springs and lifted bump stop perches
5.13:1 ratios, locked front/rear
rear is a "Vit floater" rear disk with ADD axels, gv drive flanges, flat spring plates with flat headed bolts not u bolts (can still run u bolts), full wrap bar setup, will just need a chassis mount fabricated and welded on.
front is a shaved housing, both with N/T spring spacing
both have N/T drive shaft flanges but can be changed
Both have solid pinion spacers and centers are in good condition as far as im aware, shocks will come with them but id use for mock up only, as there fucked.
Basically add front hubs, new cromo's and you have diffs built to take 35s, and the suspension setup to also give you about the right amount of lift!
2. Location - Hobart tas,
3. Willing to post at buyers expense
4. Price - 2.5K the lot.
5 Pm or post below
Genuine reason for selling, no longer required as i cant drive hard tracks anymore after spinal surgery and would like the cash to finish my rebuild.
Post Posted: Tue Sep 25, 2018 9:33 am
bumpksi
Post Posted: Tue Nov 06, 2018 8:16 pm
Still for sale
Users browsing this forum: Google [Bot] and 16 guests
