It is currently Tue Oct 20, 2026 12:52 am
Post Posted: Sun Jan 13, 2019 8:43 pm
Sierra rear sway bar $60
Suzuki LJ20 offer
I would like all the Suzuki stuff to go in one big hit so if you want to put an offer for it all put an offer in for it all
0406398032 thanks Doug
North Brisbane Strathpine
Vitara
$30 3x rear diff housings
$40 3x front Vitara brake caliper hubs
$50 3x rear differential
$50 2x front differential
$25 6x CV
$40 Vit hubs
$45 alternator
$10 throttle cable
$15 sway bar
$10 LWB rear tail shaft
$25 lwb towbar
$30 roof racks
Sierra
$150 MS full floater rear axles
$ 25mm drive shaft spacer NT&WT
$30 2x front drive shaft
$20 2x front drive shaft
$20 NT rear drive shaft and a half
$10 3x steering box
$30 steering arms
$10 3x starter motor
$45 alternator
$10 ignition coil
$10 metal window winders
$5 2x carburettor throttle cable
$30 gearbox rear housing Jimny kit
$45 Jimny chassis mounts
$20 1L centre dash control
$10 1L speedo Dash
$5 1L glove box lid
$10 1L steering wheel
$10 NT handbrake drum with cable
Jimny
$180 Jimny for braced housing
$20 5x front drive shaft
$20 rear drive shafts
$20 sway bar
$30 Jimny steering arms
$20 panhand arms
$15 airbox intake pipe
$40 vvt gearbox broke
$15 vvt transfer case pulled apart
$10 3x pair upper tail light
$5 indicator brake light
$25 rear axles with brake drums
$40 rear diff housings
$20 non vvt rear gearbox bracket
$15 exhaust shield
$20 M Series sump
$20 vinyl bottom seats pre vvt
XL7
$40 Chrome outside door handles
$30 inner Chrome door handles
$40 chrome grill inserts
$25 Chrome Centre hub covers
$45 brake booster
$30 spare tyre carrier cover
$15 aircon thermo fan
Post Posted: Wed Feb 20, 2019 12:47 pm
I want these parts gone ASAP buy multiple stuff in get stuff for free
Post Posted: Wed Feb 27, 2019 8:30 pm
Hey Doug, what's "MS" Full float axles? I'm wondering if they're compatible with the JML kit.
Also, this might sound stupid, but do you have the suzuki 's' badge from the front of the sierra? Mine fell off =)
Vehicle: Twin cam Sierra
Post Posted: Fri Mar 01, 2019 12:09 pm
Hi
Are the front driveshafts 22 spline for the sierra? and are they wide track?
Thanks
Twin Cam Sierra 4" lift 31's
Post Posted: Mon Mar 11, 2019 11:59 am
Sorry totally forgot I posted this stuff up here yes they should work 0406 398 032 I'll send you photos and measurements
Users browsing this forum: No registered users and 29 guests
