It is currently Fri Oct 16, 2026 6:54 am
Post Posted: Fri Oct 20, 2023 5:24 pm
Hi all, unfortunately it's time for me to part ways with my Sierra. It's been an awesome little run about but it needs a fair bit of work to make rego and itll need a blue slip since it just passed the 3 month mark since rego ran out. I'm advertising it here before anywhere else as i'd love for it to go for someone that's into them. I'll put as good of a description as i can below and won't pull any punches. For pics please hit me up and i'll email them to you.
1988 Suzuki Sierra Soft top located in Newcastle NSW
The good
Strong engine, serviced every 10,000kms
New 2 inch exhaust
Aftermarket extractors, unsure what brand as they came on the car
New Seatbelts
New headlamps
Comes with roll bar that hasn't been fitted
Has rear seats that were taken out when i first got the car
The bad/ugly
The carpet has been removed as has the sound deadening. The front seats aren't in great condition, the drivers side has been worn down on the right side from getting in and out of the car and the passenger side does not decline. When i went to get a pink slip the list included a leaking tappet cover, sump plug has a slow leak, front wheel bearings need adjustment, the right front hub is leaking (may just need adjusting) and the drainage holes in the body need plugging. I did the front wheel bearings and swivel hubs myself around a year ago so i'd assume they just need adjusting to stop leaking. All of the parts involved are reasonably new in any case, i've probably only done around 5000kms driving since they were done. Theres some slight rust at the top part of the door frame which doesnt appear to be structural and theres a small rust hole in the left rear wheel well that needs patching. Stereo has been removed although the wiring is still there.
I think that about covers it, i'm after $3200 for the car although am negotiable. If you're interested or would like to know more contact me on 0421604594 or send an email to sean_oultram@hotmail.com. PS As said above if you're after pics please contact me and i'll email them to you.
Users browsing this forum: Google Adsense [Bot] and 50 guests
