It is currently Fri Oct 16, 2026 4:41 am
Post Posted: Mon Dec 11, 2023 9:13 am
Up for sale is my pride and joy Vitara. I’ve owned THEVIT for 14 years. Purchased as a completely stock car,it has been built over the years with countless hours into the rig. I am the second owner. 289k on the clock. Meticulously maintained and in excellent condition inside and out. Extremely capable and built to be used as such. Everything has been built as strong as these Vits can get. All Parts sourced from Low Range Off-road in the states/ADD engineering. Billet machining locally.
Mods:
Full Calmini 3” Super Articulation Kit
3” 4XFour Art rear springs
Old Man Emu Nitro Front Struts
Old Man emu Nitro extended shocks in rear
31” BFG Muddies on Kings Sunnies
Rear Spare mount modified for up to 32” tyres
ADD Engineering fuel tank Bash plate
Safari Snorkle
Billet Unbreakable Idler Arm
Rear Disk Brake conversion
Front Steel GV diff housing
Front Lockrite locker
Billet Chromoly RH stub shaft(now takes 2 bolt in cvs) Nylon internal bush.
Rear Diff has a minispool fitted
4.24:1 Billet Crawler Transfer case gears
Exceedy Heavy duty clutch
Extractors
Large water separator fuel filter
2-1/4” exhaust
Tube Rock Sliders
ARB delux winch bar with 7” LED spotties
9500lb winch with remote
ARB compressor mounted under bonnet
Diffs, transfer, gearbox breathers
LED underbody lighting
LED reverse Light
Tinted windows
Rola Roof Rack
Ironman side awning
Optima Yellow top start battery(new)
100AH deep cycle for second(new)
Multiple USB outlets in front and rear
Red Arc battery Isolator
600W inverter on tailgate
Tailgate table
MSD blaster 3 ignition coil
UHF Radio
Under Seat mounted Amp
Pioneer Bluetooth Head-unit
King Draws in rear
Anderson Plug at rear for Solar Input/12V output
Hayman Reese towbar with flat 7 pin plug
Less than 5,000kms ago
Rear axle bearings replaced
Transfer case rebuilt, all new bearings
Front wheel bearings
Timing Belt/Water pump
Optima Yellow Top
100AH deep cycle
Calmini rear bush set
Drag link and tie rods
Tailshaft Unis
Rear brake pads
Carburettor Rebuild
Rebuilt Front hubs
Radiator hoses
Spare tailshafts, full engine gasket set, 2 extra complete sets of wheel. 1 set of Kings high offset black sunnies with 31” tyres, 5 alloys with good All terrain stock size tyres.
Always stored in a locked up garage. Full central locking with alarm system and immobiliser. THEVIT will be terribly missed but it just doesn’t get out often anymore due to the family needing a larger 4x4. The car is ready to be enjoyed by the new owner. Sold no roady or rego.
SOLD
Located Bendigo, Victoria. Chris 0448 664 686
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Jan 08, 2024 9:55 am
Hi Chris,
Still for sale?
Post Posted: Mon Jan 08, 2024 10:27 am
Sure is mate.
Post Posted: Thu Jan 11, 2024 7:07 am
Mad not to buy it at this price.
Cant even come close to setting something like this up for the price.
And this stuff is rare on the second hand market.
Post Posted: Tue Feb 27, 2024 3:19 pm
SOLD
Users browsing this forum: No registered users and 77 guests
