[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
FullyZooked
Joined: Mon Oct 25, 2010 9:01 am Posts: 1009 Location: Bendigo
 Posted: Mon Dec 11, 2023 9:13 am |
Up for sale is my pride and joy Vitara. I’ve owned THEVIT for 14 years. Purchased as a completely stock car,it has been built over the years with countless hours into the rig. I am the second owner. 289k on the clock. Meticulously maintained and in excellent condition inside and out. Extremely capable and built to be used as such. Everything has been built as strong as these Vits can get. All Parts sourced from Low Range Off-road in the states/ADD engineering. Billet machining locally.
Mods:
Full Calmini 3” Super Articulation Kit 3” 4XFour Art rear springs Old Man Emu Nitro Front Struts Old Man emu Nitro extended shocks in rear 31” BFG Muddies on Kings Sunnies Rear Spare mount modified for up to 32” tyres ADD Engineering fuel tank Bash plate Safari Snorkle Billet Unbreakable Idler Arm Rear Disk Brake conversion Front Steel GV diff housing Front Lockrite locker Billet Chromoly RH stub shaft(now takes 2 bolt in cvs) Nylon internal bush. Rear Diff has a minispool fitted 4.24:1 Billet Crawler Transfer case gears Exceedy Heavy duty clutch Extractors Large water separator fuel filter 2-1/4” exhaust Tube Rock Sliders ARB delux winch bar with 7” LED spotties 9500lb winch with remote ARB compressor mounted under bonnet Diffs, transfer, gearbox breathers LED underbody lighting LED reverse Light Tinted windows Rola Roof Rack Ironman side awning Optima Yellow top start battery(new) 100AH deep cycle for second(new) Multiple USB outlets in front and rear Red Arc battery Isolator 600W inverter on tailgate Tailgate table MSD blaster 3 ignition coil UHF Radio Under Seat mounted Amp Pioneer Bluetooth Head-unit King Draws in rear Anderson Plug at rear for Solar Input/12V output Hayman Reese towbar with flat 7 pin plug
Less than 5,000kms ago
Rear axle bearings replaced Transfer case rebuilt, all new bearings Front wheel bearings Timing Belt/Water pump Optima Yellow Top 100AH deep cycle Calmini rear bush set Drag link and tie rods Tailshaft Unis Rear brake pads Carburettor Rebuild Rebuilt Front hubs Radiator hoses
Spare tailshafts, full engine gasket set, 2 extra complete sets of wheel. 1 set of Kings high offset black sunnies with 31” tyres, 5 alloys with good All terrain stock size tyres.
Always stored in a locked up garage. Full central locking with alarm system and immobiliser. THEVIT will be terribly missed but it just doesn’t get out often anymore due to the family needing a larger 4x4. The car is ready to be enjoyed by the new owner. Sold no roady or rego.
SOLD
Located Bendigo, Victoria. Chris 0448 664 686
_________________ Built Suzuki's shall reign Victorious.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Mon Jan 08, 2024 9:55 am |
Hi Chris, Still for sale? Cheers
_________________ your daily dose of questionable sanity
FullyZooked
 Posted: Mon Jan 08, 2024 10:27 am |
Sure is mate.
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Thu Jan 11, 2024 7:07 am |
Mad not to buy it at this price.
Cant even come close to setting something like this up for the price. And this stuff is rare on the second hand market.
FullyZooked
 Posted: Tue Feb 27, 2024 3:19 pm |
SOLD
[ 5 posts ] |
Users browsing this forum: No registered users and 55 guests
