i have 2" extended shackles and want to go back to either standard or 30mm longer ones.. these were prof made but my angles are all wrong with them.
if someone can make pro 30mm extended ones then ill straight swap em.
pm me cheers guys
i have 2" extended shackles and want to go back to either standard or 30mm longer ones.. these were prof made but my angles are all wrong with them. if someone can make pro 30mm extended ones then ill straight swap em. pm me cheers guys
I have some I made they are 40mm longer than std or some other stocko one but some pins are a little pitted
David
_________________ Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
