It is currently Wed Oct 07, 2026 1:18 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Post Posted: Mon May 23, 2011 4:00 am
sideways wrote:
Thanks mate but it's not what I'm looking for sorry. I'm after a clutch for an LJ50 which I'm sure is different to that.
Thanks
Hayden
http://www.ebay.com.au/itm/Clutch-kit-S ... _955wt_905
Good bloke to deal with
Post Posted: Mon May 23, 2011 2:05 pm
tonyevans wrote:
Thanks
Hayden
Thanks, I was going to get one from them, just can't use one yet so the money has better things to be spent on.
Has anyone got a drivers side inner guard/battery tray? Mines pretty dead. 8O
Thanks
Hayden
Post Posted: Thu May 26, 2011 1:07 pm
ah well, good luck with the build
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Tue May 31, 2011 11:46 pm
Thanks
Hayden
Mine was much worse then that, weld a flat sheet in there if the rest of the guard is ok.
Post Posted: Wed Jun 01, 2011 2:15 pm
Fity wrote:
Thanks
Hayden
Mmm I figured they all rust pretty bad there. Do the inner and out guards separate? It doesn't look like they do. My outer guards are stuffed, the inner one is good apart from the rust.
Post Posted: Thu Jun 02, 2011 2:00 am
The inner and outer guards are 2 pieces which are spot welded together. If you had a really good inner and a really good outer you could try and cut and shut them. The place in Columbia sells them separate I think.
Post Posted: Thu Jun 02, 2011 2:15 am
Yeah, that's pretty much what I thought. I think I'l fix mine up the best I can and make tube frame guards later. Mine are really bent and have rust pinholes everywhere.
Thanks
Hayden
Users browsing this forum: No registered users and 25 guests
