It is currently Thu Sep 03, 2026 5:31 am
Post Posted: Mon Apr 12, 2010 4:07 pm
What I am after is the outside part of a front LHS drive shaft tripod joint.
The bit that bolts onto the diff drive flange with three bolts.
Post Posted: Mon Apr 12, 2010 4:11 pm
got an axle here but it's a 22 spline?
it looks like this
or do you need the flange & cup from the LHS CV?
post a pic. also model and year would be nice :)
Post Posted: Mon Apr 12, 2010 4:19 pm
i posted this in the ebay thread earlier today.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 500wt_1182
it's for a vitara i'm guessing.
i do have a LHS CV cup floating around but it was slightly damaged during the exploding CV incident.
let us know what you need.
Post Posted: Mon Apr 12, 2010 5:01 pm
The part on the left is much larger than a Zuke part.
But the Zuke equivalent, the outer triangular cup for the tripod joint.
A damaged one, would be fine, I only really want to look at it and measure it up.
The part I want bolts directly onto this flange...........
Post Posted: Mon Apr 12, 2010 5:11 pm
i've got one here it's yours to keep if you cover postage?
the vitara CV's are VERY different to that, i'm hoping these pics might help?
Post Posted: Mon Apr 12, 2010 5:22 pm
If it has 23 splines, I may still be able to use it.
Post Posted: Mon Apr 12, 2010 5:28 pm
hmmmm, 23 spline is that a typo?
the early vitara's have an inner spline of 22 or the later ones are 26 spline?
i've got no idea on what the spline count on the hub end.
Post Posted: Mon Apr 12, 2010 5:37 pm
This GTR shaft I have here, has 23 splines at inner end, and 22 splines at the outer end.
I have seen the Vitara outer CV joints advertised on e-bay also having 22 splines.
It might still be workable if I use the Vitara shaft along with the Vitara inner CV, if the shaft lengths are similar.
This shaft is 360mm overall, or 330mm from center of spline to center of spline which may be easier to measure if the shaft is assembled.
Post Posted: Mon Apr 12, 2010 5:48 pm
i don't have a complete shaft here, just the broken on in the photo's.
i can post either just the cup that bolts onto the axle, or i can box up & post the axle, the cup & the rest of the broken LHS if you want?
Post Posted: Mon Apr 12, 2010 8:04 pm
I have a good pair of 94 Vit SWB CV's here... $50 plus post.
Post Posted: Tue Apr 13, 2010 12:23 am
hub end is 26 spline aswell
Go Hard, Trailer Home
Users browsing this forum: No registered users and 14 guests
