| Wanted: 26 spline side gears http://auszookers.com/forum/viewtopic.php?f=8&t=10409 |
| Author: | Red_October [ Sat Mar 13, 2010 2:23 pm ] |
| Post subject: | Wanted: 26 spline side gears |
No rush but i'm contemplating selling the front locker and upgrading to a locked 26spline cromo setup. If anyone's got them in good nick then let me know. Cheers, Jimmy. |
| Author: | steak_knife [ Sat Mar 13, 2010 2:29 pm ] |
| Post subject: | Re: Wanted: 26 spline side gears |
What locker is in it?? You should be able to get side gear's for it, thay just rear's.. |
| Author: | want33s [ Sat Mar 13, 2010 2:31 pm ] |
You want air locker side gears or stock zook? ARB sell a side gear kit... |
| Author: | steak_knife [ Sat Mar 13, 2010 2:32 pm ] |
Or I will swap you a std 26 spline for your locker.. |
| Author: | Red_October [ Sat Mar 13, 2010 2:36 pm ] |
Its an ARB air locker - the front one (RD75) I didn't know you could get side gear kits for them. I'll have a chat with my local ARB bloke and see what he can do. |
| Author: | rythwrist [ Sat Mar 13, 2010 3:13 pm ] |
i wanted to swap someone my front air for a rear air but had no luck i have the 26 spline side gear kit coming from the states for my air locker cheaper to buy over there than here just takes a little longer. $262us and $350 aus cheers heath |
| Author: | Brett [ Sat Mar 13, 2010 3:16 pm ] |
hopw much you want for the locker? i have some side gears here. |
| Author: | Red_October [ Sat Mar 13, 2010 3:29 pm ] |
Rythwrist, you don't happen to have part numbers I can quote? Or a link? Sorry Brett, looks like I'm hanging onto it as long as I can get the side gear kit. |
| Author: | rythwrist [ Sat Mar 13, 2010 3:35 pm ] |
the part number for the set is 728g011 kit is 4 star gears and the 2 side gears. best price i could get was about $315 but i guess it who you know that counts |
| Author: | DSzuke [ Sat Mar 13, 2010 3:51 pm ] |
rythwrist wrote: ... i have the 26 spline side gear kit coming from the states for my air locker cheaper to buy over there than here just takes a little longer. $262us and $350 aus
cheers heath Is that the the ARB kit from the US you got? I have the same problem and need the kit at some stage to refit my locker. I was quoted $380 here for the kit so haven't bothered yet. |
| Author: | rythwrist [ Sat Mar 13, 2010 4:01 pm ] |
yer it's weird, us is still cheaper, low range buy the the side gear kit from aus - aus post to us, then us post back to me in aus and still works out cheaper arb have so much mark up on the products. i have rock assualt chromo coming from low range and the side gear kit for about $760 and to buy the chromo's from states and side gear from here was going to work out about $950 back in the day it was cheap you use to be able to just buy the side gears which were like $60 each |
| Author: | Bruce [ Thu Jun 02, 2011 11:47 am ] |
Grave dig here sorry. So if I get this 728g011 kit, I should be able to fit that to my RD75(altho I have the older style RD 73 which has the same part number 728g011 ) front Air locker and then run 26 chrome axles? |
| Author: | zooky08 [ Thu Jun 02, 2011 9:13 pm ] |
Bruce wrote: Grave dig here sorry. That's is corrected As far as I know
