Joined: Sat Jun 06, 2009 11:30 pm Posts: 203 Location: SA
Posted: Tue Mar 30, 2010 4:29 am
They are really hard to get. I tried for a while on the forums.
Wreckers wanted around $500 for one here.
Is it for an efi motor into a sierra? If so there are other ways..
Good luck!
Posted: Fri Apr 09, 2010 5:05 am
I used a holesaw to cut around a 100mm hole into my standard leafy fuel tank and then I put in fuel pump from an et turbo I had in the yard, which goes down to about 5mm from the bottom of the tank. I then made some brackets on the fuel pump and mounted a swirl pot to it.
Couldnt ask for any better! Keep the same fuel gauge, stock tank and everything looks original:)
Users browsing this forum: No registered users and 7 guests
