| Wtb, Vitara fuel tank and efi pump http://auszookers.com/forum/viewtopic.php?f=8&t=10750 |
| Author: | superduki [ Tue Mar 30, 2010 1:58 am ] |
| Post subject: | Wtb, Vitara fuel tank and efi pump |
As the title states, chasing a efi vit tank with internal pump. Im located in tassie, so closer to here the better. Cheers Superduki. |
| Author: | zookfun [ Tue Mar 30, 2010 4:29 am ] |
| Post subject: | Re: Wtb, Vitara fuel tank and efi pump |
They are really hard to get. I tried for a while on the forums. Wreckers wanted around $500 for one here. Is it for an efi motor into a sierra? If so there are other ways.. Good luck! |
| Author: | superduki [ Wed Mar 31, 2010 1:10 am ] |
Ah bugger! Yeah thats what I'm chasing, cause of the size and fitment to a flat tray. What other sort of tanks around that size could work? Cheers, Superduki. |
| Author: | zookfun [ Fri Apr 09, 2010 5:05 am ] |
I used a holesaw to cut around a 100mm hole into my standard leafy fuel tank and then I put in fuel pump from an et turbo I had in the yard, which goes down to about 5mm from the bottom of the tank. I then made some brackets on the fuel pump and mounted a swirl pot to it. Couldnt ask for any better! Keep the same fuel gauge, stock tank and everything looks original:) |
