It is currently Fri Sep 04, 2026 4:42 am
Post Posted: Tue Mar 30, 2010 1:58 am
As the title states, chasing a efi vit tank with internal pump.
Im located in tassie, so closer to here the better.
Cheers Superduki.
GTi Turbo & A LWB Sierra.
Post Posted: Tue Mar 30, 2010 4:29 am
They are really hard to get. I tried for a while on the forums.
Wreckers wanted around $500 for one here.
Is it for an efi motor into a sierra? If so there are other ways..
Good luck!
Post Posted: Wed Mar 31, 2010 1:10 am
Ah bugger! Yeah thats what I'm chasing, cause of the size and fitment to a flat tray. What other sort of tanks around that size could work?
Cheers, Superduki.
Post Posted: Fri Apr 09, 2010 5:05 am
I used a holesaw to cut around a 100mm hole into my standard leafy fuel tank and then I put in fuel pump from an et turbo I had in the yard, which goes down to about 5mm from the bottom of the tank. I then made some brackets on the fuel pump and mounted a swirl pot to it.
Couldnt ask for any better! Keep the same fuel gauge, stock tank and everything looks original:)
Users browsing this forum: No registered users and 25 guests
