| Bits for 93 LWB Vitara http://auszookers.com/forum/viewtopic.php?f=8&t=11343 |
| Author: | DarkHorse [ Thu Apr 22, 2010 10:19 am ] |
| Post subject: | Bits for 93 LWB Vitara |
Hey all, Just got this home, and keen to turn the shopping trolley into a mini Monster truck:
Just wondering if anyone has any of these kicking around that they want to get rid of: Bits for a 2" inch suspension lift, both ends 2" body lift Steel front diff (Lux or GV) Bullbar Snorkel Steering wheel boss Roof racks Wider, big offset steelys (7s?) and/or 235 ATs Flares Drop me a line if you have any of this, and let me know how much you want for it! Cheers! Rob. |
| Author: | DAFFY [ Thu Apr 29, 2010 1:08 pm ] |
| Post subject: | Re: Bits for 93 LWB Vitara |
ive got a set of 7 x 15' alloy mags x 4 that i want $150 for n my mate has a body lift siting around still i think matt 0402348938 |
| Author: | DarkHorse [ Fri Apr 30, 2010 3:46 pm ] |
Hey Daffy - thanks mate, I'll give you a buzz when I get a chance - rims sound good, and BL if everything's there would be great! So I had it down at the mechanics for a Blue slip to transfer the rego. The bad = shocks and struts are cactus, handbrake needed adjusting. The not too bad = slow oil leak from rear main seal, muffler has collapsed. Cleared the ECU to isolate the 'Check Engine' light error that pops up at freeway speeds, and there may be a small leak in the power steering pump. So my suspension plans have shot up the list, as I need to sort it to get the rego done. I've been shopping around, and the retail options are: OME from ARB - $1600 fitted Tough Dog from Opposite Lock - $1600 fitted ($1800 from TJM) Ironman from 4WD1 - $880 supplied only Calmini - US$980 supplied only I only paid $3,000 for the car, so $1.5k+ is a bit hard to stomach. Is the IronMan stuff OK, or worth paying the extra for OME/TD? Other options are the Commo shocks and 180SX coils down back, or there are a couple of Rancho shocks going second hand which look OK, but who really knows? A member on another forum has offered me used Tough Dog stuff for the back end reasonably cheap, but new stuff up front is still nearly a grand. The front end I need new struts anyway, so should I just bite the bullet? I've also ben looking at bars - ARB do a steel winch one for $1250, or ECB still have an alloy non-winch one for $1600 through Opposite Lock. ARB lockers are about $1600 each end, plus $500 for the compressor (fitted) so that will have to wait while! I have found a used steel diff from a V6 hopefully. Snorkel is going to cost $550 from ARB or Opposite Lock. I've found a second hand body, but the rest of the kit from ARB will cost $200 Rola racks $450 from ARB or more from OL. SuziTech want $1200 for a full exhaust, extractors, 2.5" to the cat, 2" there back. I did grab two pairs of Flexi Flares that I can chuck on sometime. Damn this stuff gets expensive fast!!! The possible mitigator is that if I get a bunch of stuff from ARB they can move a little bit. |
