It is currently Wed Sep 02, 2026 3:54 am
Post Posted: Mon May 03, 2010 1:19 am
OK, so I got hung up on a large log that was buried in the sand on Bribie Island on Saturday morning and the cross member under the gearbox/ transfer case copped a hiding
I'm near North Lakes Brisbane.
Anyone got a straight one?
BCNU Jabba
Post Posted: Mon May 03, 2010 1:53 am
yep, got one from a manual, it should fit.... but i'm in SA. $30 + postage.
Post Posted: Mon May 03, 2010 8:17 pm
PM sent
BCNU Jabba
Post Posted: Tue May 04, 2010 8:15 am
When you have the member out, have a REAL good look at the chassis mount's, the driver's one look's to be bent to.
Post Posted: Tue May 04, 2010 8:30 am
i'll pack it up tomorrow & get a price, i'd think it will be about $10 for postage.
have you got an address you want me to send it to or do i send it to Steknig & he'll fit it for you?
Post Posted: Tue May 04, 2010 9:09 pm
Thanks Atari4x4
I can fit it, but I'm a bit worried about steknigs' comment about the bent chassis mount. That might be a problem
Where is Steknig anyway I'm Brisbane North Side up near North Lakes
I will send you a PM about the address
BCNU Jabba
Post Posted: Wed May 05, 2010 8:50 am
jabba wrote:
Thanks Atari4x4
Replyed. :P
Post Posted: Wed May 05, 2010 9:17 pm
OK.
So I climbed under the car last night and had a closer look at the chassis mounts.
They both "look" straight although the bolts on the passenger side don't look quite right, like they are a bit off vertical if you know what I mean. Like one or both of the bolts have been pushed a bit with the twisting of the cross member. I'm guessing there is some clearance with the holes so it should work out OK. Might need new bolts if the others are damaged though. Easy
I guess I will need to put a straight edge on them and also check for square when the member is out.
The worst thing is that the box and tfr case is sitting a little sideways - not much - but noticeable.
See how I go with the replacement member when I get it
Thanks for your help/ advice so far
BCNU Jabba
Post Posted: Thu May 06, 2010 7:14 am
looking at the pic the member is a lil twisted, so the box straighten up when you bolt the other on in.
Users browsing this forum: No registered users and 3 guests
