| LWB NT sierra chassis http://auszookers.com/forum/viewtopic.php?f=8&t=17573 |
Page 1 of 3 |
| Author: | Fatzook [ Fri Dec 17, 2010 5:42 am ] |
| Post subject: | LWB NT sierra chassis |
Mines fucked. Anyone got a spare needle lying in their haystack? |
| Author: | JrZook [ Fri Dec 17, 2010 6:37 am ] |
| Post subject: | Re: LWB NT sierra chassis |
Bah just glue it back together! |
| Author: | tonka_tuff [ Fri Dec 17, 2010 6:48 am ] |
cable ties?? |
| Author: | Fatzook [ Fri Dec 17, 2010 6:50 am ] |
I can weld myself out of most problems, but this is well beyond me |
| Author: | steak_knife [ Fri Dec 17, 2010 6:50 am ] |
Fatzook wrote: I can weld myself out of most problems, but this is well beyond me
I can weld problem's, so we could work as a team.. |
| Author: | Fatzook [ Fri Dec 17, 2010 6:52 am ] |
tonka_tuff wrote: cable ties??
My MIG can't applt cable ties. Wrong handpiece |
| Author: | Joe [ Fri Dec 17, 2010 6:54 am ] |
What happened? did you find more rust |
| Author: | Fatzook [ Fri Dec 17, 2010 6:56 am ] |
Joe wrote: What happened? did you find more rust
No. The chassis is bent. There are a few Kinks here and there and evidence that someone has applied heat (oxy) to the rail at a certain point to try and fix it, and in doing so, they have collapsed the rail, making it weak and irrepairable. Not happy. |
| Author: | Joe [ Fri Dec 17, 2010 7:00 am ] |
Bugger |
| Author: | dank [ Fri Dec 17, 2010 7:02 am ] |
Fatzook wrote: Joe wrote: What happened? did you find more rust No. The chassis is bent. There are a few Kinks here and there and evidence that someone has applied heat (oxy) to the rail at a certain point to try and fix it, and in doing so, they have collapsed the rail, making it weak and irrepairable. Not happy. No Option to laminate the affected area? |
| Author: | shep [ Fri Dec 17, 2010 7:04 am ] |
i have one you can have. 85 SJ51 i can chuck it on the roof of the merc when ball and i drive to brisvegas in may. |
| Author: | Fatzook [ Fri Dec 17, 2010 7:08 am ] |
No. Its in a shitty spot. I'll get a pic up of it on the weekend. Its between the drivers side rear transfer case mount and the rear cab crossmember, along the underside of the rail. The indentation is about 20mm deep. The inside of the rail above this has popped out about 10-15mm. The top has sunken. To repair this I would have to heat, stretch it from the rear of the chassis, and lift the rail back up at the same time. Given that some asshat has already had a crack at it, I can see this area already being pretty fatigued. All this would need to be done on an alignment jig. And the 2 days spent straightening it would probaly cost me more than just buying a beater ute with a straight chassis as a donor. |
shep wrote: i have one you can have. 85 SJ51 i can chuck it on the roof of the merc when ball and i drive to brisvegas in may.
Hahaha Thanks I need this thing on the road in Jan though |
| Author: | christover1 [ Fri Dec 17, 2010 7:57 am ] |
I have a lwb nt 1.o litre chassis in melbourne. christover |
| Author: | christover1 [ Fri Dec 17, 2010 8:01 am ] |
| Author: | Fatzook [ Fri Dec 17, 2010 8:33 am ] |
hmmm Transport might be an issue. I'll see what I can turn up in brisbane first. |
| Author: | christover1 [ Fri Dec 17, 2010 8:44 am ] |
Fatzook wrote: hmmm
Transport might be an issue. I'll see what I can turn up in brisbane first. Some guy off here from nsw was arranging a ute, a mate and some time off to come get it..not heard a thing since |
| Author: | steak_knife [ Fri Dec 17, 2010 9:46 am ] |
Fatzook wrote: hmmm
Transport might be an issue. I'll see what I can turn up in brisbane first. We could be back by monday, share the drive you pay the ticket's... |
| Author: | Fatzook [ Fri Dec 17, 2010 10:10 am ] |
steak_knife wrote: Fatzook wrote: hmmm Transport might be an issue. I'll see what I can turn up in brisbane first. We could be back by monday, share the drive you pay the ticket's... How about it Christover? Is the chassis in RWC? Stekky and I may need to drive it north |
| Author: | steak_knife [ Fri Dec 17, 2010 10:15 am ] |
It's got more steel that butterslut did.. Tow ya lil trailer behind the vit.. |
| Author: | atari4x4 [ Fri Dec 17, 2010 10:17 am ] |
make an A frame up & drag it back. |
| Author: | christover1 [ Fri Dec 17, 2010 10:18 am ] |
You would need some reindeers to pull it, its just a sled now, no wheels,axles or anythings |
| Author: | christover1 [ Fri Dec 17, 2010 10:22 am ] |
I have 2 LWB rear tailshafts (1.0L) too. And the snorkle. Thought they'd go quick. |
| Author: | shep [ Fri Dec 17, 2010 10:36 am ] |
mine is a roller, and probably the same distance as Melbourne not really |
| Author: | christover1 [ Fri Dec 17, 2010 10:40 am ] |
shep wrote: mine is a roller, and probably the same distance as Melbourne not really
Mine was a roller, it fell over quite a lot, think I hold club record for side flops |
| Author: | Fatzook [ Sat Dec 18, 2010 4:40 am ] |
bump. |
| Author: | shep [ Sat Dec 18, 2010 4:46 am ] |
isn't mine or christover1's good enough for ya? |
| Author: | steak_knife [ Sat Dec 18, 2010 5:17 am ] |
shep wrote: isn't mine or christover1's good enough for ya?
Not enough bling on it |
| Author: | Fatzook [ Sat Dec 18, 2010 6:02 am ] |
Sure are. Can I build my ute at your place? You already have the chassis |
| Author: | steve [ Sat Dec 18, 2010 8:13 am ] |
Fatzook wrote: I need this thing on the road in Jan though
What's happening in January? |
| Page 1 of 3 | All times are UTC + 9:30 hours |
