It is currently Wed Nov 04, 2026 1:30 pm
Post Posted: Sun Jan 02, 2011 11:09 pm
Anyone have a spare starter moter they wanna sell or swap for a 6 pack of coronas? Already cold and will come with limes :) cut or uncut
If in doubt power out!
Post Posted: Sun Jan 02, 2011 11:15 pm
just pull yours apart and clean it up, grease it and it should be good to go...
Think before you post to make AZ a better place :)
Post Posted: Sun Jan 02, 2011 11:17 pm
Cheers mate will giv it a go, it seems to hav had it tho:(. Won't try to kick or anything, turn the key, no noise
Post Posted: Sun Jan 02, 2011 11:23 pm
they arent that expensive new mate.. and are readily available.
Post Posted: Sun Jan 02, 2011 11:38 pm
Yeh I'll look for a new one later on in life, just need one that works and is cheap for now tho
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Sun Jan 02, 2011 11:40 pm
Try giving the solenoid a few taps with a hammer.
When they get old they stick.
Otherwise there's plenty on ebay.
Katherine 2013!
Post Posted: Mon Jan 03, 2011 12:01 am
Will do, just checked on eBay they r like 200:/
Vehicle: My12 Defender 90
Post Posted: Mon Jan 03, 2011 12:24 am
buy a mazda 121 starter from wreckers (no more that $30) it spins the wrong way and has incorrect snub nose. but the solenoid is identical. swap solenoid over and if you feel up to it pull the stator apart and swap the brushes over and you have a working starter (well one with a new solenoid and new brushes dont forget to clean it all at the same time. did this to mine the other week and works a dream. watch those ebay ones they dont all fit correctly. had to send one back to the seller as it was shit and didn't fit correctly i suspect he had sent me a swift/barina one instead. not a hard job though. or just call jas he will probs have some normally about $50
lil starter motors for our toys are only 2 pole, they do not wear out, as in slow down, use extra power to get them going, they just stop, cold.
They will work perfect up until the thing shits itself, no indication that anything is wrong.
Get a auto sparky to test it if you don't have a multimeter, (if you dont, get one and learn the basics, saves you shitloads of dollars) and take it from there.
200 is chiken shit when you think of breaking down somewhere all alone.
Post Posted: Mon Jan 03, 2011 3:33 am
and someone is watching you and will attack you and kill you!
I saw a yota forum where the guy put a air barb on it, and when he went throught water/mud he would put positive presure through it to keep it clean. he might have run it off of his AC comp....
Post Posted: Mon Jan 03, 2011 5:04 am
Hahaha turns out it tWas the immobilizer :/
Post Posted: Mon Jan 03, 2011 6:28 am
Those thing's are awesome when you drive through water.. :wink:
Users browsing this forum: No registered users and 9 guests
