It is currently Sun Nov 01, 2026 10:46 am
Post Posted: Sun May 08, 2011 4:38 am
Looking for a good crankshaft assembly or a whole 3 cyl 2 stroke motor for a LJ50
Post Posted: Wed May 11, 2011 1:00 am
Come on Guys - I know you have heaps of them laying around - Someone must need the room - Tony
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Wed May 11, 2011 5:58 am
We all need more room for more parts. :P
After 30 + years of zinging around a good bottom end would be hard to find. Rebuild what you have is probably going to be the best bet.
Post Posted: Wed May 11, 2011 6:04 am
If I can find someone to do it AND the parts :blink:
Post Posted: Wed May 11, 2011 9:06 am
Hey Tony, Give izook a PM he has a running 2stroker that he wants to get rid of. Dont laugh it runs and is mech in good nick just teh body is toast. A good reason why you shouldn't let kids have a free run with a farm car.
Yes it goes stop laughing :roll:
Post Posted: Wed May 11, 2011 11:46 am
Thanks RIKSTR - PM sent - Would you have an Email address for him?
Post Posted: Thu May 12, 2011 2:02 am
Can't believe how good the seats are, I have a hard top with much worse seats. 8O
Post Posted: Thu May 12, 2011 2:05 am
I think that's just the covers surviving a bit
Post Posted: Thu May 12, 2011 3:49 am
PM sent
Post Posted: Sun May 15, 2011 1:31 am
This is currently on e-bay, but although the cylinder casting says LJ50, this didn't come out of an LJ50 4x4. It is a late production low pollution model without the oil feed to the cylinders, as discussed on page 2 of the LJ tech and picture thread. The inlet manifold and carby is of the Carry style, and the transfer case attached to the gearbox is definately not LJ, probably a 4x4 Carry, but I didn't think these were availble in the 2 stroke, only F5A efi??
Anyway, if it is tested as claimed to be, the engine itself will fit into a late LJ50 (Bellhousing bolt pattern changed between late '74/early '76) if you use your LJ50 inlet manifold and carb. Probably cheaper than a crank rebuild!
Post Posted: Sun May 15, 2011 1:54 am
Yes I saw that - a lot of bits missing too.
Post Posted: Sun May 15, 2011 1:58 am
Only the Starter Motor and Alt+bracket.
Post Posted: Sun May 15, 2011 6:33 am
Do you know what the gearbox is that it has bolted on in the picture?
Users browsing this forum: Google [Bot] and 5 guests
