| winch bar and 1.3 transfer case http://auszookers.com/forum/viewtopic.php?f=8&t=21913 |
| Author: | joel [ Fri May 13, 2011 11:19 am ] |
| Post subject: | winch bar and 1.3 transfer case |
im after a winch bar (arb, tube whatever) and a 1.3 w/t transfer in vgc condition, with or without reduction gears. cheers joel |
| Author: | shep [ Fri May 13, 2011 11:25 am ] |
| Post subject: | Re: winch bar and 1.3 transfer case |
joel wrote: im after a winch bar (arb, tube whatever) and a 1.3 w/t transfer in vgc condition, with or without reduction gears.
cheers joel i have a 1.0 box that is the same case as a 1.3. your ute transfer should be able to take gears as well. |
| Author: | joel [ Fri May 13, 2011 11:44 am ] |
the ute has a 1 liter still in it. just thought a 1.3 case and gears would gear it down a bit more. whats the 1liter case is equal to a 1.3 with what gears? |
| Author: | Fatzook [ Fri May 13, 2011 12:41 pm ] |
joel wrote: the ute has a 1 liter still in it.
just thought a 1.3 case and gears would gear it down a bit more. whats the 1liter case is equal to a 1.3 with what gears? Nope. 1L is lower than 1.3. Keep what you have. |
| Author: | joel [ Fri May 13, 2011 1:01 pm ] |
how much lower? i was aware its a cheap alternative for 1.3 owners to gear them down, but i want to run 31s and maybe 33s later on so i was going to get a 1.3 case and throw some 5.14:1 in it, or will it be little gain over the 1liter case. |
| Author: | Fatzook [ Fri May 13, 2011 1:09 pm ] |
You have a late model Maruti, so your case is EXACTLY the same as a WT 1.3L sierra case, only your gears are lower (12% in high). Just buy the gearset you want and install into YOUR case. If you are considering 33's then get 6.5's straight up. |
| Author: | joel [ Fri May 13, 2011 1:19 pm ] |
sweet i will check it out when i can see it. still need a bar. |
