It is currently Sat Nov 14, 2026 1:22 pm
Post Posted: Thu Aug 25, 2011 11:19 am
Need an engine in Victoria swift Sierra vitara ?has to be in Victoria what do you have ?
Sj80,31 claws, lift, winch, 6.5
Post Posted: Fri Aug 26, 2011 12:09 am
I have a G16B from a Baleno here, comes with gearbox and modified loom, everything you need to fit it straight into a Sierra (I have 2" bodylift, it should fit in a stock heighter but I cant be sure). Want $1500 neg gimme a ring 0438858325
Vehicle: Daisy
Post Posted: Fri Aug 26, 2011 12:20 am
Damn, why can't that have been in QLD :(
Post Posted: Fri Aug 26, 2011 12:37 am
Does it have the sump changed and the Ben T kit, also the right angle drive for the dizzy, or do these have to be done/sourced before fitting.
Post Posted: Fri Aug 26, 2011 12:57 am
I've got a spare G16A If that's what your after?
Post Posted: Fri Aug 26, 2011 9:06 am
Made my own adapter plate, would imagine it would be pretty much the same as BenT's, and its coilpack motor so no dizzy.
Post Posted: Fri Aug 26, 2011 10:18 am
Anyone got a G16b in QLD...
Users browsing this forum: No registered users and 3 guests
