It is currently Sun Nov 15, 2026 1:08 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
Post Posted: Fri Aug 17, 2012 6:42 pm
Hi, I'm after an SR20DET. Must be good nick with loom and computer.
-SR20 bellhousing
-C4 Auto transmission
-Rover LT230 transfer case.
Newcastle Area, NSW.
Will pay post.
Post Posted: Fri Aug 17, 2012 8:50 pm
I've got a 3 speed auto
Post Posted: Sat Aug 18, 2012 4:57 pm
EDIT.
Vehicle: stock
Post Posted: Sat Aug 18, 2012 6:06 pm
Mate I think you forgot to edit the title or are you looking at doing an engine and gearbox front and back. Or are you chasing both of them?
Post Posted: Sat Aug 18, 2012 6:18 pm
get onto www.nissansilvia.com if you want a sr20det
Post Posted: Sat Aug 18, 2012 8:32 pm
Yeah me retard.
Haha, cheers Atari and whoever edited the title.
Post Posted: Sat Aug 18, 2012 8:40 pm
In case you're interested the second gen S14 SR20s were VCT as well - stuff all difference between them and the S15s, but can be had a fair bit cheaper from my research.
Post Posted: Sat Aug 18, 2012 8:49 pm
Doesn't matter too much. I don't plan on modifying it at all other than after the dump pipe. I just have been made aware the S15's had a bit more go. Cheers.
Post Posted: Sat Aug 18, 2012 9:27 pm
SierraDan wrote:
cheers whoever edited the title.
pompoms :peaceout:
Post Posted: Sat Aug 18, 2012 11:02 pm
S15 SR20DET's sell for around $3K with loom and ECU. Front cuts are $4k and over.
LT230's are cheap as chips. Usually under $200 on ebay.
NFI what a C4 is worth these days, but maybe try some of the old aussie mussle forums.
Vehicle: 94 Sierra,99 gv, s13 Silvia
Post Posted: Sun Aug 19, 2012 7:13 am
The s15 sr20det does go a little better but for the price difference compared to a s13 sr it's not really worth it. For the extra $1500 it is for the s15 motor you can buy a s13 sr and get a decent aftermarket turbo that will give you more power/response than a standard s15 motor.
Try importers and also have a look on eBay and boostloosing as you can always come across cheap sr motors.
If u need any info on sr's feel free to ask I have blown up 6 of them. Coming from drift background before playing with sierras I have a bit of knowledge about sr's
Cheers jae
Post Posted: Sun Aug 19, 2012 8:26 am
Yeah fair enough. I'm happy to spend about $1500-2000 on a good motor. I'd prefer not to modify it too much to save blowing the motor up or something in my driveline. Just want to be able to cruise up to 100km/h with ease.
Post Posted: Sun Aug 19, 2012 10:27 am
dude stick with a s13 sr.. front mount,get a t28 (ballbearing)turbo fuel pressure reg and adjust the boost to 12psi and you will have roughly 190-200kw.. factorythey have 165kw fromj memory.. 12psi is comfortable in a sr, i had my last s13 sitting on 15psi and it copped a flogging and lasted for over a year
Post Posted: Sun Aug 19, 2012 10:32 am
don't forget the flutter, bitches loooove flutter. :lol:
Post Posted: Sun Aug 19, 2012 1:20 pm
I'd steer clear of a front mount unless you are doing only speed work.
Try and scavenge a water to air setup off a subaru. They are far more efficient when airflow is compromised.
Post Posted: Sun Aug 19, 2012 3:11 pm
have you thought about ca18det? i have a heap of them floating in my shed.
Post Posted: Sun Aug 19, 2012 4:08 pm
Not really interested in CA18. I want some decent power out of the box, plenty of available parts and something I know has worked in the driveline combo I've chosen.
And the bloke at works 180sx is shiiit haha.
Post Posted: Sun Aug 19, 2012 4:23 pm
i used to run around in a ca18det bluebird and it went fairly well. with a few mods ca18det can be just as quick as sr. plus they loooove to rev ;)
Post Posted: Sun Aug 19, 2012 4:33 pm
Yeah. Don't wanna mod anything. I'd rather just chuck it in and flog it.
Post Posted: Sun Aug 19, 2012 5:20 pm
Will see more slow stuff than fast stuff, but id like the option of going quick.
Like this one? Know what models they're on?
And what is involved in its setup?
Post Posted: Sun Aug 19, 2012 6:19 pm
Not sure which models they are on. Suby wreckers will know.
You could run something like this... http://www.ebay.com.au/itm/PWR-WATER-AIR-BARREL-INTERCOOLER-6-INCH-X-10-INCH-SUIT-TURBO-RB-2J-FORD-6-/120968408037?pt=AU_Car_Parts_Accessories&hash=item1c2a476be5
You'll need a thin radiator to ount up front of your engine radiator, an ELP ( preferably speed controlled) and plumbing.
it can be more compact than equivelant A2A coolers.
Post Posted: Sun Aug 19, 2012 6:34 pm
So it's basically it's own cooling system seperate from the engine cooling system?
Engine radiator will be in the back.
Post Posted: Sun Aug 19, 2012 9:13 pm
Yep. So if you have room for the IC radiator up front, then it will work well.
Post Posted: Mon Aug 20, 2012 6:45 pm
RS Liberty and i might be hard to find the whole set up.
Post Posted: Mon Aug 20, 2012 9:56 pm
y Sr? why not 4agze or something??sr20s are a Fucking masive 4cylinder... not sure on weight but actual size wise.
imo
4agze-4speed auto-twin lux transfers.
Post Posted: Mon Aug 20, 2012 10:00 pm
4agze's are a bit long in the tooth these days, and SR's are way more common and probably easier to find parts for
Post Posted: Mon Aug 20, 2012 10:19 pm
very true. I'm just not a fan of the Sr size department. have watched them take huge boost and make big power day in, day out without a issue for a long time tho.
ah why does it matter Dan will change his mind again well before he finds a motor lol.
Post Posted: Tue Aug 21, 2012 3:54 am
Yeah you're funny Phil....
Why a 4 speed and what 4speed? Why lux transfers? And why two?
I chose an SR for power out of the box, availability of the motor and parts and fuck I love a turbo. I'm not trying to squeeze the motor into the glovebox..
an LT230 to work in my setup needs an LT230 and an adaptor. Twin hilux cases need a heap of money spent on them and are still not that great, then my driveline is super long and I have another stick.
My driveline will be short, strong, work and have power to get the thing moving.
I'm not asking what you guys think of my choice. I'm asking for you to sell the stuff to me.
Vehicle: Jimny/110 Landy
Post Posted: Tue Aug 21, 2012 8:40 am
Keep an eye on the Aulro driveline parts for sale area. The transfers come up often enough. Or ebay, as said.
http://www.aulro.com/afvb/driveline-parts-sale/
Post Posted: Tue Aug 21, 2012 10:04 am
also Dan keep in mind Sr is a high strung motor, few seconds starved of oil and its game over.
Users browsing this forum: No registered users and 16 guests
