It is currently Sun Nov 15, 2026 1:14 pm
Post Posted: Mon Aug 20, 2012 8:58 pm
just need the 2 gears for a Rick lobster build.
prefer in tas.
Post Posted: Thu Aug 23, 2012 7:44 am
realy? no one?
Post Posted: Thu Aug 23, 2012 8:04 am
Yes .
Post Posted: Thu Aug 23, 2012 9:57 am
jonno_racing wrote:
realy? no one?
Don't be so suprised. You need parts from 2 transfer cases to make a lobster, rendering atleast one of the cases useless. Most people would rather sell a complete case than 1 piece of it.
Having said that, I MAY have the 1L gear that you need. I'll have a look at home tonight.
Post Posted: Fri Aug 24, 2012 2:12 am
While you may get the gears reasonably cheaply, the Rocklobster conversion involves cutting, fitting and welding the two halves of the counter gear back together, a fairly tight tolerance job that can be easily stuffed up and ends up creating an inherently weak point prone to failure. Why muck around when you can buy a whole set of brand new gears for a 4.16 case (including countergear beaings, countershaft and thrust washers) for under $375 plus about $40 postage?
http://www.trailtough.com/index.php?opt ... &Itemid=50
Post Posted: Fri Aug 24, 2012 10:23 am
hey guys I have the 1ltr gear set!
I only need the 1300 cluster and gear.
I know I have thrown out atleast 3 sets over the years (fitting 6.5s). that's the only reason I'm looking at doing this, as I'm using junk parts that are basically useless.
I have made a rocklobster before.. worked well for a bush only rig. a mate of mine is a machinest and is doing the work for me! so no stress!
if it wouldn't blow my budget I would just grab some 6.5s.
I have challenged myself to build a wheelable rig for $1500
Post Posted: Fri Aug 24, 2012 8:37 pm
I'll double check my shed for a 1.3 set of gears.
Post Posted: Fri Aug 24, 2012 11:43 pm
double champion
Post Posted: Sat Aug 25, 2012 2:46 am
SierraDan wrote:
Yes .
Post Posted: Sat Aug 25, 2012 10:04 am
yeah Dan but josh might have both things I need :)
Post Posted: Sun Aug 26, 2012 10:56 am
The cluster and LR gears?
I couldn't possibly have them haha
Users browsing this forum: No registered users and 15 guests
