It is currently Sat Nov 14, 2026 11:01 am
Vehicle: lj50 soft top76
Post Posted: Thu Oct 25, 2012 6:42 pm
hi all, i'm after a suzuki lj50 tie rod lever in good condition, the piviot bush can't be purchased seperatly so i have been told! :(
Post Posted: Fri Oct 26, 2012 8:05 am
Hi All,
Thorno, I can help you with this.
Greg 0428789854
Post Posted: Fri Oct 26, 2012 4:17 pm
you find a bearing of the right size and press it in. much better than the original bush
Post Posted: Sun Oct 28, 2012 9:46 am
thx Greg will give you a call,
Tanshi, have you done this before, would seem a little ridged/solid, without the rubber for flex? if that is an issue or not? or am I looking at it the wrong way not sure. all advice is appreciated
thx guys
