It is currently Sat Nov 14, 2026 11:34 am
Vehicle: vitara v6 sv620
Post Posted: Fri Oct 26, 2012 9:52 pm
need front diff and housing mine ixl ploded like jam leaking seal new i should have fixed that filled with water also rear end vibration possibly axle or diff required urgent on rear parts its also my bread winner :( metal fillings in oil plz help 0403364039
Post Posted: Fri Oct 26, 2012 10:13 pm
Where are you mate?
Post Posted: Sat Oct 27, 2012 7:58 am
I have front & rear's available from a 2.0V6 auto for $300 for the pair + freight from SA
Post Posted: Sat Oct 27, 2012 8:17 am
PM sent, i have front and rear complete out of a 2001 GV diff ratio's are apparently as follows,
5.125:1 Base 1.6L auto and manual (2001 XL-7 auto)
$200 each or $300 for both
Post Posted: Sat Oct 27, 2012 8:34 am
^^^ double check your ratio's... that doesn't seem like the right diff ratio's for a 2001 GV
Post Posted: Sat Oct 27, 2012 8:02 pm
melb chelsea would a 4cl center fit with my crown wheel ? my rear is good just needs an oil change seems a wheel weight came off and tyer became unbalanced!
Post Posted: Sat Oct 27, 2012 8:04 pm
ATARI keen on both !
Post Posted: Sat Oct 27, 2012 9:03 pm
shoot me a pm bender, is yours a manual or auto?
taken from my forsale add :wink:
Up for grabs are the complete front & rear 4.875:1 diff centres out of my SV620 auto, 86,779kms $300ono + postage, perfect to re gear that Grand Vitara after fitting larger tyres.
At this stage they're siamese twins and will not separate them, I can remove the front centre from the alloy housing to reduce freight costs
Post Posted: Sun Oct 28, 2012 5:19 pm
il buy them = $
Users browsing this forum: No registered users and 6 guests
