It is currently Sat Nov 14, 2026 10:44 pm
Post new topic Reply to topic  [ 29 posts ]
Post Posted: Wed Dec 19, 2012 7:55 pm
Chasing a drop pitman to fit a vitara power steering box. 2 or 3 inch drop would be good.
Post Posted: Wed Dec 19, 2012 8:22 pm
Calmini make one http://puresuzuki.com/kick_pitman_arm.htm IIRC these are about 17mm locker so if your diff is moved forward you may have steering binding issues.
I believe the Jimny PS pitman arms also fit the Vitara PS box, they are both a koyo brand steering box. Im sure I read on here somewhere the splines are the same. This means you can track down a standard Jimny PS Pitman arm which has about the same drop as a sierra pitman arm.
The other option is a jimny drop pitman arm http://www.jimnybits.co.uk/shop/jimny/s ... d_563.html
Post Posted: Wed Dec 19, 2012 9:18 pm
Calmini are out of stock
Post Posted: Thu Dec 20, 2012 6:04 am
I think early Tarago vans have a suitable pitman arm.
But You'd need to check that out, memory fails me.
Post Posted: Sun Dec 23, 2012 1:39 pm
Every tarago I have looked at has R&P steering.
Post Posted: Sun Dec 23, 2012 2:15 pm
Thats a bugger, will have to check my history.
Zukination/alterego list one
http://www.alteredegomotorsports.com/sa ... ering.html
Post Posted: Sun Dec 23, 2012 2:35 pm
That one fits a Sierra box, I need one to fit a vitara box.
Post Posted: Sun Dec 23, 2012 3:20 pm
My apolgies, always thought they were the same.
I'll crawl back into my box now :oops:
Post Posted: Sun Dec 23, 2012 3:30 pm
http://www.xtremezuksoffroad.com/index. ... nt=0&cat=5
Post Posted: Wed Jan 02, 2013 9:11 pm
christover1 wrote:
http://www.xtremezuksoffroad.com/index.cfm/do/Parts.Display/SidekickTrackerX90.htm?parent=0&cat=5
Never got a email back so scratch that one as well :(
Post Posted: Fri Aug 16, 2013 8:08 am
Can any one confirm that a jimmny pitman arm fits a vit box and how much drop does it give over a vit pitman arm
thanks
Vehicle: 89 Sierra
Post Posted: Wed Sep 25, 2013 11:12 am
Did anyone confirm the Jimny arm fits the vit box?
I am in the same situation...
Post Posted: Wed Sep 25, 2013 8:15 pm
I thought jimny was the same spline as sierra :?
Post Posted: Thu Sep 26, 2013 6:29 am
AFAIK Jimny box is identical to Sierra EXCEPT for the pitman spline and the pitman length.
Post Posted: Thu Oct 03, 2013 8:49 pm
vit and jimny arms are the same spline. jimny is similar drop to a sierra. I have now bought 3 jimny arms to fit to vit boxes fitted to sierra cars. $130ish dollars new from suzuki
Post Posted: Fri Oct 11, 2013 1:01 pm
Do u know how much drop they give over a vit arm
Post Posted: Fri Oct 11, 2013 1:06 pm
vitara arm is flat so i would say around 1-2 inches drop
Post Posted: Fri Oct 11, 2013 1:07 pm
this is a jimny power steer box
Post Posted: Fri Oct 11, 2013 7:32 pm
Is there a specific year Jimny Power steering pitman arm that suits the Vitara steering box, or will any of them fit?
and sorry noob question, the benefit of having the drag like and tie rod more parallel is reduced bump steer?
Vehicle: '90 Vit, 16b, high and wobbly,
Post Posted: Sun Oct 20, 2013 2:31 pm
If the pitman arm is lowered, wouldn't there need to be a similar drop for the idler arm? Is this done with a lowering bracket using the stock arm or another arm with the drop? Where do I get the bits to sort this?
Thanks
Post Posted: Sun Oct 20, 2013 2:37 pm
this is talking about fitting one to a sierra w/ vitara power steering so no idler arms etc.
Post Posted: Sun Oct 20, 2013 3:19 pm
Can someone give me the measurement from hole centre to hole centre on this, I am after one that has just a bit more throw that a stock vitara.
Post Posted: Sun Oct 20, 2013 3:24 pm
Ok thanks. I've just been looking at the calmini site and they make no mention of these parts. Can you direct me to a thread that covers this issue?
Thanks
Post Posted: Sun Oct 20, 2013 3:49 pm
there is no issue... this isn't relevant to a vitara owner, as i said above it's about a sierra with vitara power steering.
Post Posted: Sun Oct 20, 2013 4:18 pm
OK, I thought maybe I could improve the steering arm angles associated with the calmini 3" lift and the subsequent front tyre screeching when going over table top speed bumps. But if thats just part of the deal, then that's one more thing off my list!
Thanks
Post Posted: Sun Oct 20, 2013 4:42 pm
sounds like you've got other issues to deal with, i highly doubt that your tyre rub issues is caused by steering arm angles.
Post Posted: Mon Oct 21, 2013 12:23 pm
hey RIKSTA if your steering arms are made by sky, your having the same problem as I am with lack of steer angle. the jimny arm is 10ish mm longer (from memory than the vit so it doesn't make up the difference. I was a bit annoyed about this as I specifically asked sky if they were short enough to match the sierra pitman arm.
my solution which i haven't got around to finishing yet is I bought a left hand drive Toyota tie rod end kit with the relay end so I could set it up like a 60 series cruiser where the drag link is tied to the tie rod and in turn its steering the knuckle from the inner hole instead of the outer (on the left hand side steering arm)
to make this work I have to shorten my sky tie rod to fit the relay end and that's a job for someone else as I don't have the tools to do it......
Post Posted: Thu Oct 24, 2013 12:51 pm
Thanks for that Mr.G. I have the trail gear RHD hi steer and when checking with the trail tough one it was slightly different. It seems that TT had designed it to work with the shorter throw of the Vitara arm.
Its very close to working, but I could just do with a bit more. I think the jimny arm will fix the problem if it is longer by 10mm
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Mon Dec 02, 2013 6:08 pm
I have a drop pitman arm that is currently fitted to a wt steer box. Will that suit your application?
