It is currently Sun Nov 15, 2026 3:48 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Sun Dec 30, 2012 12:31 pm
Just demolished my front diff at Loveday. Need a steel one to suit an sv420 but I know they are hard to come by due to demand... Any help please point me in the right direction, based in adelaide.
Post Posted: Sun Dec 30, 2012 3:53 pm
I've got a stock ally one you can have cheap (although postage won't be) to get you through until you find one...
Post Posted: Sun Dec 30, 2012 6:44 pm
Thank you, I may be interested... Freight would be excessive from NSW.
Ill PM you if I don't fine any other options, cheers
Post Posted: Sun Dec 30, 2012 7:28 pm
i sent 2 diff centres from SA to VIC for $40... was a dollar a kg which wasn't too bad IMO.
Post Posted: Mon Dec 31, 2012 2:18 pm
Just Had a good look at my diff, freight would be substantial as i need not just the centre but the entire unit. Alloy vitara diffs really are terrible, mine is cracked/shattered everywhere!
Post Posted: Mon Dec 31, 2012 2:28 pm
i have a good alloy housing that you could grab cheap & get darky to post just the diff centre, good luck finding one local. you'll pay twice as much as what it would cost to post the whole thing from sydney. :wink:
pics of carnage NOW! :lol:
Post Posted: Mon Dec 31, 2012 3:21 pm
Sounds like a plan Atari, Here are some pics....
Post Posted: Mon Dec 31, 2012 3:29 pm
where & how did you do that Armsup
looks like it's just the pinion carrier/3rd member, has it cracked the housing part (looks a bit like a banjo)
the housing is just sitting there, shoot us a message if you need it
Post Posted: Mon Dec 31, 2012 3:50 pm
The actual diff case/housing is ok from the looks of it. So I guess the so called "pinion carrier/3rd member" is the damaged part. (im no mechanic) Fairly sure the diff centre is cactus given the lack of drive and sounds that bad boy was making.
It happened at loveday 4x4 park on a sand obstacle, so no direct impact to casing. Occurred after both front wheels left the ground, upon their return and subsequent gain of traction that a loud bang was heard, loss of drive, bits of alloy shooting every where and me swearing repeatedly.
Post Posted: Mon Dec 31, 2012 11:43 pm
:lol: Yup, that'll do it!
Rip it out and check out your ring & pinion gears, but I'd be surprised if they haven't been munched.
I can get a weight and freight quote tomorrow, and get it picked up Wednesday. Let me know what you want and where to send it. ;)
Post Posted: Tue Jan 01, 2013 10:04 am
Thanks, Ill pull it out soon and let you both know what I need. Would need to be freighted to Adelaide SA.
Thank you both for your help, I will PM you soon.
:D
Post Posted: Sun May 05, 2013 5:48 pm
Still looking for front diff centre and alloy housing to suit sv420. Cant find anything in Adelaide wreckers... or they are all just slack and never get back to me.
Post Posted: Sun May 05, 2013 7:20 pm
Get a steel housing or you'll be struggling again to get another alloy one when that one goes bang!
Post Posted: Mon May 06, 2013 6:53 pm
Id prefer a steel housing and 5"12 centres but ill take anything ... Has been off the road for a while now because I cant find anything :(
Post Posted: Tue May 07, 2013 10:29 am
My steel diff and axle housing was from Qld, it was only $80 for delivery to Melbourne.
That was complete with diff and axle still in it.
Don't be put off by freighting/postage etc.
Try online parts finders, that worked for me.
Have seen GV's for wrecking on face book, too.
Post Posted: Tue May 07, 2013 10:33 am
Sierra front steel 3rd can be made to fit, not simple, but worth considering, as supplies are better.
Or strapping down the alloy diff, to help stop explosions
Post Posted: Tue May 07, 2013 8:15 pm
Cheers ill case out interstate parts and freight
Post Posted: Tue May 07, 2013 8:36 pm
If I do look for the best option, a grand vitara steel diff what is the most suited one for a auto sv420 short wheel base? thanks
Post Posted: Tue May 07, 2013 8:56 pm
Mine was from a Manual V6 GV 1998.
Pretty sure you need a manual one, though I have heard later model autos had them.
The range of models with steel diff is in the Good Tech Bullet proof front diff thread somewhere
Post Posted: Wed May 08, 2013 6:41 pm
Thanks Again Christover1, interstate wrecker called me at 7:45 am with a standard front diff centre and alloy housing for about $300. At least with the stock Ill have some 4x4 ability
Post Posted: Tue Jun 11, 2013 6:34 pm
Would a 2.0L V6 auto 1997 vitara front diff fit my 1997 auto 2L 4cly ? I have 39 teeth on the crown wheel and 9 on the pinion.??
Post Posted: Tue Jun 11, 2013 6:41 pm
the V6 auto would be 4.8:1
Post Posted: Tue Jun 11, 2013 8:42 pm
Thanks :( wreckers tried to tell me it was the same ratio
Post Posted: Wed Jun 12, 2013 10:59 am
ok now im confused.... I require the front differential to fit a 1997 Suzuki Vitara Sv420 automatic 2L Short Wheel Base 4cl. I need the entire front diff and pinion up to where it attaches to the front drive shaft becuase it all messed up bad upon inspection. I have counted the teeth on the crown wheel; 39 and 9 on the pinion part. Im still not sure what ratio it is and apparently the wreckers cant tell me either, theirs is a 39 and 8 which i guess is 4.8.1. Just need to know if it will fit my car?? sorry for asking so many obvious questions but its doing my head in ha ha
Post Posted: Wed Jun 12, 2013 11:09 am
Ahhhhh so I would have a 4.3 ratio maybe? 39 / 9 = 4.3
Post Posted: Wed Jun 12, 2013 11:13 am
tripple check your tooth count as it doesn't quite seem right to me, was under the impression that the manual SV's were 4.6's & the auto's were 4.8's.
to work out the ratio divide 39 by 9
eg: 39/9 = 4.333:1
mark the pinion tooth you're starting with using a scribe or degrease it & use a texta, maybe with the damage you've missed a tooth when counting?
Post Posted: Wed Jun 12, 2013 11:27 am
Is it possible a previous owner did a ratio change?
Post Posted: Wed Jun 12, 2013 11:32 am
chris, i've said it before... not too many people bother doing the swap & why would you want to go from a 4.8 to a 4.3, would make it sluggish as hell???
plus, i'm certain it was a pristine one owner unmodified example before he picked it up.
Post Posted: Wed Jun 12, 2013 12:55 pm
Yes I doubt the ratio has been changed by previous owner. I will have to count again, the teeth are fair damaged so maybe but I did get two other people to check it... Thanks guys
Post Posted: Wed Jun 12, 2013 12:58 pm
so really I should have 39 on the crown and 8 on the pinion ; 39/8 = 4.8. The pinion is very munched so hopefully im just an idiot, ill check it tonight again.
Users browsing this forum: No registered users and 6 guests
