It is currently Sun Nov 15, 2026 9:53 am
Vehicle: sj40 tin top gti in the works
Post Posted: Sun Aug 11, 2013 8:16 pm
trying to put together a swift GTI engine to put in a sierra but i need the gearbox shim that goes between the gearbox and engine
Post Posted: Mon Aug 12, 2013 5:43 am
I don't have one but.....
It is called a sandwich plate.
Post Posted: Mon Aug 12, 2013 8:16 am
ok thanks the bloke at the wreckers told me it was a gearbox shim
Post Posted: Mon Aug 12, 2013 6:00 pm
Wikipedia wrote:
In automobiles, shims are commonly used to adjust the clearance or space between two parts.
http://en.wikipedia.org/wiki/Shim_(spacer)
The block to gearbox interface needs no adjustment.
The sandwich plate is there to accurately locate the starter motor. Called a sandwich plate because it is sandwiched between the block and the bellhousing. :wink:
Post Posted: Mon Aug 12, 2013 6:19 pm
Thanks for the info, I was only going of what i'd been told. Now i know.
Post Posted: Tue Aug 20, 2013 10:08 pm
I got one pm if interested
Users browsing this forum: No registered users and 3 guests
