It is currently Sat Oct 24, 2026 8:23 am
Vehicle: 04 GV 3dr
Post Posted: Tue Aug 06, 2013 2:03 pm
Hey guys, just got hold of a front steel diff for my GV. Now I have the 4.8 centres in it atm but am looking at putting bigger tyres on it, So am chasing down some 5.12's. Have found a pair but he is asking $800 for em. Not sure if this is reasonable or not haha. Any help would be great :D
Vehicle: 99 Grand Vitara
Post Posted: Tue Aug 06, 2013 7:31 pm
$800 is waaaay too exy. I paid $50 for a complete vit alloy diff with 5.12s and $100 for the rear diff.
http://www.strictly4x4.com.au
Post Posted: Tue Aug 06, 2013 7:32 pm
yep, what he said, $100 is the going rate around here :wink:
Vehicle: 04 GV 3dr
Post Posted: Tue Aug 06, 2013 7:34 pm
Haha yeah I figured it was way expensive. But also knew they were pretty rare. Cheers guys i'll keep searching
Post Posted: Tue Aug 06, 2013 11:44 pm
http://www.ebay.com.au/itm/Suzuki-Vitar ... cae&_uhb=1 here is some at a ok price
Post Posted: Tue Aug 06, 2013 11:47 pm
that's 2 fronts :wink:
Vehicle: 1999 grand vitara 2.5ltr
Post Posted: Thu Aug 22, 2013 9:46 am
Guys is it possible to get steel 3rd member with 5.125's or are they all alloy?
Post Posted: Thu Aug 22, 2013 9:59 am
Don't think any of the GV's came with 5.12s except the SWB, but not sure if they came with steel diffs :/ Will be easier to find them out of a vitara anyway.
Have a browse through here. Has what came with what.
viewtopic.php?f=17&t=6614
You're looking for a 92-98 EFI 1.6 either 5 speed man or 4 speed auto in 2 or 4 door. Or a 1.6l manual CARBY 2 door
Post Posted: Thu Aug 22, 2013 10:05 am
5.12 = alloy
Post Posted: Thu Aug 22, 2013 10:09 am
Thought that might be the case. :(
So swap the ring and pinion into gv steel 3rd member and carrier?
Or can the alloy take a beating in steel housing?
Thanks for quick replies
Post Posted: Thu Aug 22, 2013 10:10 am
swap it, those alloy 3rds are really weak
Post Posted: Thu Aug 22, 2013 10:12 am
Haha damn thought that was the case. Thanks for the help guys
Post Posted: Thu Aug 22, 2013 10:22 am
go see Boss Differentials in Lonsdale to get the 5.12 swapped into your GV steel diff.
Post Posted: Thu Aug 22, 2013 10:40 am
Haha cheers atari. Trying to get the parts for rowdee so I can have his 4.8 :)
But will definitely look em up since there down the road
Post Posted: Thu Aug 22, 2013 11:24 am
Haha new question guys. Can I buy a 4.8 ratio already in steel 3rd member so it's a bolt over swap and give rowdee my current steel bits so only one of our cars has to go into diff place?
Post Posted: Thu Aug 22, 2013 11:41 am
i think you might find a 4.8 in a steel diff out of a very late model GV v6 auto... most were alloy from memory, or are the GV v6 auto's 4.6? :?
Post Posted: Thu Aug 22, 2013 11:43 am
Thanks mate. Ill do some searching for years.
Post Posted: Thu Aug 22, 2013 11:47 am
4.8 pretty sure
Post Posted: Thu Aug 22, 2013 11:51 am
http://nbs4x4club.com/forum/index.php?t ... 78.20;wap2
Scroll down a bit but info is there for anyone else doin what I'm doing.
Post Posted: Thu Aug 22, 2013 11:53 am
you'll need the pinion mount too if you find one from a late model GV
Post Posted: Thu Aug 22, 2013 12:05 pm
Not 100% sure what that part is but I thought it would come already on a center?
Post Posted: Thu Aug 22, 2013 12:09 pm
Duebakka wrote:
http://nbs4x4club.com/forum/index.php?topic=14178.20;wap2
I'm certain that info isn't 100% correct, Joe's SWB auto GV had 4.8's in an alloy front not 5.12's as listed below: viewtopic.php?f=4&t=7632&hilit=gv+swb&start=1260
i'm sure that list of ratio's has been posted here before. :?
1.6 GV man + auto = 5.125
2.0 4cl GV Auto = 5.125 Alloy diff
2.0 4cly GV Manual = 4.8 Alloy diff
2.5 V6 GV Auto = 4.8 Steel diff after 2003
2.5 V6 GV Manual = 4.3 Steel diff
if it's anything like the SV's the manual 2.0 4cyl would have 4.6's & the auto 4.8
Post Posted: Thu Aug 22, 2013 12:12 pm
depends on what the wrecker pulls off when removing it. they both bolt up the same, i think on the SWB you'll want the early model for sump clearance
late model
early model
closer one is late model
late model / early model
Post Posted: Thu Aug 22, 2013 12:17 pm
Naa rowdee has the 2ltr Manuel and it has 4.8 and I also got a rear diff from same car in my current car and can confirm it is 4.8
Oh I understand now. Makes sense
Post Posted: Thu Aug 22, 2013 12:21 pm
Duebakka wrote:
Naa rowdee has the 2ltr Manuel and it has 4.8 and I also got a read diff from same car in my current car and can confirm it is 4.8
ahhh, well then that must mean both the auto & manual GV SWB 2.0 4 cylinder have 4.875:1 seeing you got 4.8's out of a 5 speed & joe's swb also had 4.8's.
that might differ on the rareish GV LWB 2.0's.
oh suzuki why you so cuntfusing. :?
Post Posted: Thu Aug 22, 2013 12:26 pm
Hmm only thing I can think of is joes swb musnt have had overdrive? :S
Post Posted: Thu Aug 22, 2013 12:29 pm
it's an AW4 with OD
Post Posted: Thu Aug 22, 2013 12:34 pm
O.o shall be known as suzfusion
Post Posted: Thu Aug 22, 2013 5:17 pm
Ok so hopefully I haven't missed anything otherwise I'm a terrible researcher haha but can anyone confirm I have all the parts needed to swap 4.8 to 5.125 in rowdee's car.
I have sourced these:
Complete steel diff assembly
5.125 center
And pinion mount
Once the diff guy has changed the ratios and put the diff together
Is it just a matter of bolting it in? Thank you
Users browsing this forum: No registered users and 21 guests
