Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
cal213
Joined: Fri Oct 12, 2012 9:01 pm Posts: 308 Location: traralgon vic
Vehicle: jimny g13bb, 99 wrx!
 Posted: Mon Sep 02, 2013 10:06 am |
Chasing a diff centre in good condition for a rear jimny g13bb manual
Bugsta
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
 Posted: Mon Sep 02, 2013 10:52 am |
What you are looking for is a 4.09 ratio. Commonly (incorrectly) referred to as 4.1.
Crown 45 teeth. Pinion 11 teeth.
The same diff was also in the M13a (non VVT) models and also the auto m13aa (VVT) models.
This may help you identify when you go to a wrecker, or search Gumtree, eBay etc.
Good luck.
cal213
 Posted: Mon Sep 02, 2013 2:01 pm |
Thats the sort f info i need. I havent yet opened her up but the whine and backlash i get is pretty bad.
Bugsta
 Posted: Mon Sep 02, 2013 2:57 pm |
If you would like a few percent reduction, you could always replace both front and rear diffs with the 4.3 ratio, which are found only in the Manual VVT model. 4.3 R&P suitable for the rear can also be found in one series of Vitara front. Removed when doing a alloy to steel housing conversion. Cannot remember which model.
edit: if you have lockers however, one of them is different. Not sure which.
cal213
 Posted: Mon Sep 02, 2013 8:13 pm |
The locker doesnt replace any of the r&p right? Thought about getting one in. But im pretty sure my gears will be ugly. All info in regards to what i can do is also greatly appreciated, thanks bugsta. Lots of misleading stuff kicking around sadly
Bugsta
 Posted: Mon Sep 02, 2013 8:28 pm |
Correct, but there are 3 lockers listed for the Jimny. 1 is the same between models. The other different. Not sure what it is.
What do you mean gears will be ugly?
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 24 guests
