http://auszookers.com/forum/
Qld. Mk2 or 3 swift gti dizzy
http://auszookers.com/forum/viewtopic.php?f=8&t=43520
Author:  Junior_91 [ Mon Oct 21, 2013 8:07 pm ]
Post subject:  Qld. Mk2 or 3 swift gti dizzy
Hey guys I'm chasing a mk 2 or 3 dizzy for a swift gti head. Ipswich Brisbane area. Changing from mk1 angle adapter for aftermarket management. Pm or reply here.
Cheers chris
Author:  jonno_racing [ Mon Oct 21, 2013 9:32 pm ]
Post subject:  Re: Qld. Mk2 or 3 swift gti dizzy
i have built a few angle drives but dont have the pieces around to build anymore. if u get the bits i will build you one mate.
Author:  masterA [ Tue Oct 22, 2013 10:35 am ]
You built a angle drive kit for a MK2/MK3 dizzy?
Author:  Junior_91 [ Tue Oct 22, 2013 1:53 pm ]
No it's mk1 now I'm changing to mk2 or 3 and want to get rid of the angle drive. Sorry.
Author:  JrZook [ Tue Oct 22, 2013 2:35 pm ]
What aftermarket management? Will it be compatible with the odd trigger wheel spacings of the mk2/3's?
Author:  jonno_racing [ Tue Oct 22, 2013 2:40 pm ]
sorry i didn't read it right!
Jr is on to it tho, you might be better off with a g16b dizzy (this is the exact reason a g16b dizzy wont work with a mk2/3 gti and angle drive)
Author:  JrZook [ Tue Oct 22, 2013 4:28 pm ]
Could just stick to the Mk1 and gut the dizzy so it just acts as the cam sensor. Very similar setup as the early VR type G16B dizzy.
Author:  jonno_racing [ Tue Oct 22, 2013 4:29 pm ]
at a guess id say it would be running a sierra dizzy...
Author:  Junior_91 [ Wed Oct 23, 2013 9:12 am ]
I'll probably end up with a haltech sprint 500. So would I just be able to run my current one as a sensor for the computer or will I need to change it?
Author:  Junior_91 [ Wed Oct 23, 2013 9:13 am ]
So a g16b dizzy will go straight in?
Author:  JrZook [ Wed Oct 23, 2013 9:24 am ]
Yes as long as the ECU accepts variable reluctance sensor input. All you have to do with your dizzy is lock out all advance mechanisms and unsolder/remove the ignition coil driver inside of it.
Author:  Junior_91 [ Wed Oct 23, 2013 7:30 pm ]
Righto thanks. I'll look into it further.
