| (SA) 1.3 Transfer Case hand brake Drum http://auszookers.com/forum/viewtopic.php?f=8&t=53183 |
| Author: | azzas15 [ Tue Sep 06, 2016 11:02 am ] |
| Post subject: | (SA) 1.3 Transfer Case hand brake Drum |
Hi All, Looking for a complete 1.3 Transfer case hand brake drum. Happy to pay freight Had to swap my 1 litre transfer case for a 1.3 and the drums are not compatible Please let me know if you have one. Cheers, Aaron |
| Author: | just_cruizin [ Tue Sep 06, 2016 12:19 pm ] |
| Post subject: | Re: (SA) 1.3 Transfer Case hand brake Drum |
So you just want the actual drum and assembly with cable? I have one you can have. |
| Author: | just_cruizin [ Tue Sep 06, 2016 12:20 pm ] |
Just got to sort freight out |
| Author: | Toomanycars [ Tue Sep 06, 2016 12:25 pm ] |
Go on line to ego-couriers. Their rates are cheap, they are very fast and it is all done on line and all you need to get a quote is put in your postcode...receivers post code...weight and dimensions...I got a set(4) of rex mags and tyres up from Sydney to Bris for $110 to my door.. Xr 200 honda engine from Bris to Port Hedland (wa) for $80.. |
| Author: | azzas15 [ Tue Sep 06, 2016 1:23 pm ] |
Hi Just_cruizin, thanks for that more than happy to pay you for it. Yes just after the full drum and the cable would be great if you have it. Let me know the size and weight and I'll sort out the courier. Thanks heaps! Sent from my Nexus 6P using Tapatalk |
| Author: | azzas15 [ Thu Oct 27, 2016 8:41 am ] |
Bump. Still looking for one. Thanks Sent from my Nexus 6P using Tapatalk |
| Author: | greenzook89 [ Tue Nov 01, 2016 8:03 am ] |
I have one, it has the small flange pattern on it though. |
| Author: | azzas15 [ Wed Feb 22, 2017 11:41 am ] |
Hi All, still looking for a handbrake drum to suit the 1.3 transfer case. Cheers Sent from my Nexus 6P using Tapatalk |
| Author: | sideways [ Wed Feb 22, 2017 1:00 pm ] |
What tailshafts are you running mate? There's 2 kinds of drum that will fit. One has 1l tailshaft bolt pattern (52x52) and the other is 1.3l SJ50 (56x56). There's also SJ70 sierra tailshaft pattern which never came with a transfer handbrake, that's 60x60. Early 1l (non-switch transfer) drums don't fit. |
| Author: | azzas15 [ Thu Feb 23, 2017 12:02 pm ] |
I'm running a 1 litre shafts with a hybrid uni so I can run the 1.3 transfer case. So I would need the sj50 56x56. If I can find a complete case I'll just grab the whole thing Sent from my Nexus 6P using Tapatalk |
