It is currently Sun Nov 01, 2026 12:27 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
Post Posted: Tue Jan 12, 2010 4:51 am
WANTED: Vitara 5.12 crownwheel and pinion to go into Sierra.
I think it's the CW & P out of the front of an auto Vit that I need.
PM please if you can help.
Will pay cash or swap for Sierra stuff.
Jas.
Post Posted: Tue Jan 12, 2010 5:11 am
Yes you need front only.
Vehicle: LJ50V, SJ70
Post Posted: Tue Jan 12, 2010 5:20 am
And it's the Manual Vit with the 5.125s. Autos have 4.625.
Post Posted: Tue Jan 12, 2010 12:41 pm
only the 3 speed auto 1.6 has 4.6, the 4 speed version has 5.1.
Post Posted: Tue Jan 12, 2010 4:10 pm
ive got 5.12's on my sierra with 31" tyres. 110km/h is around 4000rpm, kinda high but gets up to 110k real fast!
Post Posted: Tue Jan 12, 2010 5:54 pm
Mine doesn't see road use anymore so if it can do 80km/h with 5.12's and 35's I'll be happy.
Have one CW&P set just need another and a bag of $$$ for 35's :roll:
Post Posted: Tue Jan 12, 2010 6:06 pm
So when you gunna change your namer from want33s to want35s hehe.
Post Posted: Wed Jan 13, 2010 4:41 am
I have 2 x 4.6 diffs that were removed from the front of AW4 fitted vitaras.
Post Posted: Thu Jan 14, 2010 1:04 am
How much are you willing to pay Jas? i know graham at suzi sport springwood has a few sets . i paid 175 for my spare set but have since seen them on here for as little as 50.
35"s, are you going to start braking some serious shit.5.12s aren't famous for being strong. hilux diffs????
no wheelin till it's back on the road registered
Post Posted: Thu Jan 14, 2010 1:31 am
Don't want to pay anything really. :wink: Got a complete centre sitting here(5.12:1 alloy) that was free. :D
Hilux/Bundy diffs might eventually be an option but I'd like to go as far as possible on Suzuki parts first. :D
Post Posted: Fri Jan 22, 2010 3:43 pm
Bump... Still after a 5.12 CW&P
Post Posted: Wed Feb 10, 2010 2:12 pm
Still looking...
Post Posted: Wed Feb 10, 2010 3:26 pm
want33s wrote:
Still looking...
Would my wagon have them :?
Post Posted: Wed Feb 10, 2010 3:47 pm
joseph wrote:
want33s wrote:
Still looking...
If it's a manual or a 4 speed auto it should have 5.12's.
Post Posted: Wed Feb 10, 2010 6:58 pm
want33s wrote:
joseph wrote:
want33s wrote:
Still looking...
Its a 5 Speed manual how fast do ya need them????
Post Posted: Wed Feb 10, 2010 7:21 pm
Only want the front and by the end of the month would be great...
How much incl. freight?
Post Posted: Wed Feb 10, 2010 8:05 pm
If your going to run the vit diff gears, are you still
going to run your 6.5 transfer gears? 8)
Post Posted: Wed Feb 10, 2010 9:49 pm
I was just thinking about the front end i think its gunna be a real bugger to get out as i cant get to the drivers front wheel to pull the axel out...
This might be a dumb question but will the rear one go in the front??????
Post Posted: Wed Feb 10, 2010 10:54 pm
No, crown wheel's to big.
Use a gas axe to get it apart. :roll:
Post Posted: Wed Feb 10, 2010 10:59 pm
Dont have one ill still try but......might be a bit ezyer once the motor is out ill roll the car over to get to it :P
Post Posted: Wed Feb 10, 2010 11:00 pm
I've done that to change a clutch. :roll:
Post Posted: Wed Feb 10, 2010 11:05 pm
Ive done it to change a tyre :roll:
Post Posted: Sat Feb 13, 2010 2:43 pm
one stop suzi shop at nerang has a couple of 5.12 diffs sitting in there shed. give them a call.
86 lwb trayback, soa 33's. 1.6 armstrong stearing.
Post Posted: Mon Jul 25, 2011 9:42 am
Hi guys,
I would want a pair(front and rear) crown and pinion to put on a Gypsy(Samurai). The stock axle ratios are -
Gearing:
1st 3.652
2nd 1.947
3rd 1.423
4th 1.000
5th 0.795
Reverse 3.466
TC-High: 1.409
TC-Low: 2.268
Axle: 3.73:1
Would the stock axles work with the Vitara crown and pinion. ?
Hope to get some help....!
Regards
Sparky
Post Posted: Mon Jul 25, 2011 4:17 pm
Can anyone confirm is the part number for the Rear differential's Crown ring of the 1.6 vitara - 2745160a11ca
Thank You
Post Posted: Tue Jul 26, 2011 3:10 am
Thank You
You know from reading the above that the Vitara Rear ring and pinion is too big to fit in a Sierra axle? It's only the front that will fit a Sierra.
Anyway, which Vitara do you want the the part number for? SWB/LWB, Man/Auto, SE416/SV416/SQ416. Just about all have different part numbers and ratios available.
Post Posted: Tue Jul 26, 2011 5:34 am
303zuke wrote:
Thank You
So you suggest i get two front ones, one for the front diff of my Sierra and one for the other or only change the front one? I see you were looking for the same thing sometime back, were you able to source it?
Post Posted: Tue Jul 26, 2011 8:19 am
If you wish to fit 5.12 ratios to your diffs in a Gypsy/Samurai/Santana/Sierra/Caribean you will need TWO Vitara FRONT crownwheel and pinion sets.
They are readily available (used) here in Australia. I have two sets.
Buying new may be a bit more difficult.
Post Posted: Tue Jul 26, 2011 9:02 am
you have a pm
Post Posted: Wed Jul 27, 2011 12:51 pm
Ok and i use the Gypsy/samurai/sierra Axles with crownwheel and pinion sets? How much do the used ones cost ?
Users browsing this forum: No registered users and 13 guests
