http://auszookers.com/forum/
Vitara 5.12 crownwheel and pinion to go into Sierra
http://auszookers.com/forum/viewtopic.php?f=8&t=9164
Page 1 of 2
Author:  want33s [ Tue Jan 12, 2010 4:51 am ]
Post subject:  Vitara 5.12 crownwheel and pinion to go into Sierra
WANTED: Vitara 5.12 crownwheel and pinion to go into Sierra.
I think it's the CW & P out of the front of an auto Vit that I need.
PM please if you can help.
Will pay cash or swap for Sierra stuff.
Jas.
Author:  Fatzook [ Tue Jan 12, 2010 5:11 am ]
Post subject:  Re: Vitara 5.12 crownwheel and pinion to go into Sierra
Yes you need front only.
Author:  303zuke [ Tue Jan 12, 2010 5:20 am ]
And it's the Manual Vit with the 5.125s. Autos have 4.625.
Author:  joeblow [ Tue Jan 12, 2010 12:41 pm ]
only the 3 speed auto 1.6 has 4.6, the 4 speed version has 5.1.
Author:  ninjadaniel [ Tue Jan 12, 2010 4:10 pm ]
ive got 5.12's on my sierra with 31" tyres. 110km/h is around 4000rpm, kinda high but gets up to 110k real fast!
Author:  want33s [ Tue Jan 12, 2010 5:54 pm ]
Mine doesn't see road use anymore so if it can do 80km/h with 5.12's and 35's I'll be happy.
Have one CW&P set just need another and a bag of $$$ for 35's :roll:
Author:  SuziBlu [ Tue Jan 12, 2010 6:06 pm ]
So when you gunna change your namer from want33s to want35s hehe.
Author:  Fatzook [ Wed Jan 13, 2010 4:41 am ]
I have 2 x 4.6 diffs that were removed from the front of AW4 fitted vitaras.
Author:  16ZUK [ Thu Jan 14, 2010 1:04 am ]
How much are you willing to pay Jas? i know graham at suzi sport springwood has a few sets . i paid 175 for my spare set but have since seen them on here for as little as 50.
35"s, are you going to start braking some serious shit.5.12s aren't famous for being strong. hilux diffs????
Author:  want33s [ Thu Jan 14, 2010 1:31 am ]
Don't want to pay anything really. :wink: Got a complete centre sitting here(5.12:1 alloy) that was free. :D
Hilux/Bundy diffs might eventually be an option but I'd like to go as far as possible on Suzuki parts first. :D
Author:  want33s [ Fri Jan 22, 2010 3:43 pm ]
Bump... Still after a 5.12 CW&P
Author:  want33s [ Wed Feb 10, 2010 2:12 pm ]
Still looking...
Author:  Joe [ Wed Feb 10, 2010 3:26 pm ]
want33s wrote:
Still looking...
Would my wagon have them :?
Author:  want33s [ Wed Feb 10, 2010 3:47 pm ]
joseph wrote:
want33s wrote:
Still looking...
If it's a manual or a 4 speed auto it should have 5.12's.
Author:  Joe [ Wed Feb 10, 2010 6:58 pm ]
want33s wrote:
joseph wrote:
want33s wrote:
Still looking...
Its a 5 Speed manual how fast do ya need them????
Author:  want33s [ Wed Feb 10, 2010 7:21 pm ]
Only want the front and by the end of the month would be great...
How much incl. freight?
Author:  ZookiMonsta [ Wed Feb 10, 2010 8:05 pm ]
If your going to run the vit diff gears, are you still
going to run your 6.5 transfer gears? 8)
Author:  Joe [ Wed Feb 10, 2010 9:49 pm ]
I was just thinking about the front end i think its gunna be a real bugger to get out as i cant get to the drivers front wheel to pull the axel out...
This might be a dumb question but will the rear one go in the front??????
Author:  steak_knife [ Wed Feb 10, 2010 10:54 pm ]
No, crown wheel's to big.
Use a gas axe to get it apart. :roll:
Author:  Joe [ Wed Feb 10, 2010 10:59 pm ]
Dont have one ill still try but......might be a bit ezyer once the motor is out ill roll the car over to get to it :P
Author:  steak_knife [ Wed Feb 10, 2010 11:00 pm ]
I've done that to change a clutch. :roll:
Author:  Joe [ Wed Feb 10, 2010 11:05 pm ]
Ive done it to change a tyre :roll:
Author:  known2 [ Sat Feb 13, 2010 2:43 pm ]
one stop suzi shop at nerang has a couple of 5.12 diffs sitting in there shed. give them a call.
Author:  Sparks [ Mon Jul 25, 2011 9:42 am ]
Hi guys,
I would want a pair(front and rear) crown and pinion to put on a Gypsy(Samurai). The stock axle ratios are -
Gearing:
1st 3.652
2nd 1.947
3rd 1.423
4th 1.000
5th 0.795
Reverse 3.466
TC-High: 1.409
TC-Low: 2.268
Axle: 3.73:1
Would the stock axles work with the Vitara crown and pinion. ?
Hope to get some help....!
Regards
Sparky
Author:  Sparks [ Mon Jul 25, 2011 4:17 pm ]
Can anyone confirm is the part number for the Rear differential's Crown ring of the 1.6 vitara - 2745160a11ca
Thank You
Author:  303zuke [ Tue Jul 26, 2011 3:10 am ]
Thank You
You know from reading the above that the Vitara Rear ring and pinion is too big to fit in a Sierra axle? It's only the front that will fit a Sierra.
Anyway, which Vitara do you want the the part number for? SWB/LWB, Man/Auto, SE416/SV416/SQ416. Just about all have different part numbers and ratios available.
Author:  Sparks [ Tue Jul 26, 2011 5:34 am ]
303zuke wrote:
Thank You
So you suggest i get two front ones, one for the front diff of my Sierra and one for the other or only change the front one? I see you were looking for the same thing sometime back, were you able to source it?
Author:  want33s [ Tue Jul 26, 2011 8:19 am ]
If you wish to fit 5.12 ratios to your diffs in a Gypsy/Samurai/Santana/Sierra/Caribean you will need TWO Vitara FRONT crownwheel and pinion sets.
They are readily available (used) here in Australia. I have two sets.
Buying new may be a bit more difficult.
Author:  Brett [ Tue Jul 26, 2011 9:02 am ]
you have a pm
Author:  Sparks [ Wed Jul 27, 2011 12:51 pm ]
Ok and i use the Gypsy/samurai/sierra Axles with crownwheel and pinion sets? How much do the used ones cost ?
Page 1 of 2 All times are UTC + 9:30 hours
