It is currently Wed Nov 04, 2026 9:01 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Fri Oct 09, 2009 1:32 am
I though I would post up some step by step pic of a pair of heads I am making.
They might be of interest to the 2 stroke suzuki owners 8)
Basic setup in the mill to drill the hold down bolt holes and centre hole for insert
Boring centre hole
Flycutting top face
Post Posted: Fri Oct 09, 2009 1:56 am
Squaring up the sides
Post Posted: Fri Oct 09, 2009 1:57 am
mmmmmmmmmmm............................ :P
Post Posted: Fri Oct 09, 2009 1:58 am
oooo... I like these threads
Post Posted: Fri Oct 09, 2009 2:09 am
i like shiny stuff. :wink:
Post Posted: Fri Oct 09, 2009 2:27 am
NO I LIKE SHINY STUFF MORE
Post Posted: Fri Oct 09, 2009 12:03 pm
my racing motto has always been.
if ya cant be fast then ya should be flash. :wink:
Vehicle: 90 WT ST Locker, Tyres
Post Posted: Fri Oct 09, 2009 8:21 pm
i love 2 stroke zooks SERIOUSLY WHERE DO I BUY ONE ???
Post Posted: Tue Oct 27, 2009 1:22 am
I had a chance to get back to my heads today.
Roughing out the insert pocket
Drilling water galleries
Slotting water galleries
More tomorrow hopefully 8)
Post Posted: Tue Oct 27, 2009 1:29 am
nice, watching a block turn into a head :P
Post Posted: Tue Oct 27, 2009 1:51 am
There are going to be 2 of them. They are prototypes for a formula 500 speedway engine.
For my next trick I am going to carve out a crankcase, cylinder and more heads for a drag bike, but that won't be until next year. I am still undecided on the configuration I want.
Post Posted: Tue Oct 27, 2009 1:59 am
Are you making the entire eng? I have had the privilege of seeing a crank made from billet, only because I told him he couldn't do it 8)
Post Posted: Tue Oct 27, 2009 2:14 am
Most of it.
Some parts just aren't worth the hassle to make and it's cheaper/easier to buy them.
Pistons, rings, conrods, valve springs and any bearings will be purchased. I will probably buy the valves as blanks and turn them up to my specs. The crankcase, cylinder and the head(s) I will carve from billet.
The crank isn't a problem. I will rough it out, send it for heat treating and have someone finish grind it for me unless I get my hands on a crank grinder before then.
I want to go with 4 cylinder as they seem to be the fastest on the track at the moment. All the V twins are struggling to run the numbers.
Post Posted: Tue Oct 27, 2009 2:19 am
2.2ltr four with front mount supercharger but with desmo valve train.
bet ya cant make it. :wink: :D
Post Posted: Tue Oct 27, 2009 2:23 am
Why stop at 2.2ltr ????
Post Posted: Tue Oct 27, 2009 2:27 am
cos that leaves room for making it bigger :D . plus you wont ride it and i might
get worried if it is too big. :oops:
Post Posted: Tue Nov 03, 2009 7:06 am
Lets be truthful you are already scared of it. lol :)
Post Posted: Tue Nov 24, 2009 4:18 am
so......whats happening. :D
Post Posted: Tue Nov 24, 2009 4:39 am
Picked up some inserts for my boring bar in Darwin last week and will probably get back to them tomorrow.
I spent today fixing a poxy caravan that had it's wheels hanging off due to piss poor maintenance
Post Posted: Tue Nov 24, 2009 12:41 pm
Just out of interest what inserts are you using Ball?
Post Posted: Tue Nov 24, 2009 1:26 pm
damo if he got them in Darwin they are probably hairyforbs Chinese jobbies.
Post Posted: Tue Nov 24, 2009 2:14 pm
Yep they are from hairy forbes, the brand is vandurit. Never tried these ones before and was all I could get on short notice. I will let you know if they are garbage.
All my lathe tooling is decent kennametal gear, just some of the mill tooling is chinese.
I have a couple of chinese made endmills with inserts in them and they are brilliant on the manual mill. I don't think they would hold up on a machining centre though.
Post Posted: Tue Nov 24, 2009 5:52 pm
Good to know you're getting some decent results with Chinese stuff, as that's probably all I can afford!
Post Posted: Tue Nov 24, 2009 6:11 pm
The inserts I just got were pretty much the same price as the quality ones I know work well :?
Post Posted: Thu Dec 03, 2009 3:39 am
u really have ur head screwed on tight ball that is some artistic shit
if u have me all those tool i still be hitting it with a rock :roll:
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Thu Dec 03, 2009 1:22 pm
you a boiler maker? :lol:
Post Posted: Thu Dec 03, 2009 3:50 pm
He's a checkout chick :lol:
Goodwork Ball.
I can make many things. But not main components!
Post Posted: Mon Dec 07, 2009 3:00 am
im a deli bitch get it right lol
-indebt 4x4 club-
Post Posted: Mon Dec 07, 2009 3:25 am
thats some good work ball when its do are you going to strap a rocket to it it might make all the diffrence
 Profile YIM
Post Posted: Mon Dec 07, 2009 4:08 am
Work has come to a halt on the heads. I want to turn the inserts up next but I need my big lathe back together.
I will post up some pics of the bits I have been making to rebuild the electronic side of it tomorrow.
I can also use the lathe to make more rocket engine casings and my dirty great big hybrid rocket engine :twisted:
