It is currently Sat Oct 03, 2026 11:34 am
Post Posted: Thu Feb 18, 2010 11:46 pm
I have been a long time owner of vitara's going on 5 years. I have always found them to be reliable and most of all easy to fix. However i am having a problem now that i can't beat. The front wheel bearing nut. How in the world do you get this off. That circle nut with the four nojne threaded holes have something to do with it i'm sure. Any easy tips or tricks would be helpful.
While i'm here the problems i have encounted. Broking clutch cable from short from battery. I have replaced to clutch's in vitara's i have owned two. The second time was a waste of a day due to the clutch was fine and the pedal had snapped welded that back together for free. Broke reverse lights gearbox switch broken fuel pump i replaced too of this also. Leaking rear brake cylinder's changed one this afternoon and two on previous car. I have replaced front brake pads. Replaced fuel tank after impalling it. I think that's about it.
Oh and do your vitara's hate e10 too? both of mine have carried on like second hand lawn mower if you use it.
Post Posted: Thu Feb 18, 2010 11:55 pm
you undo the screws and remove the 'locking' tab first then the nut is done up to seven million foot pounds, I find a punch and large hemmer sorts it out
Post Posted: Fri Feb 19, 2010 12:00 am
First off welcome to AZ matey its the best suzuki site around :P
For ya wheel bearing have a look through here i done mine a few weeks back
http://www.auszookers.com/index.php?nam ... sc&start=0
If ya still not sure just ask matey :wink:
Post Posted: Fri Feb 19, 2010 12:23 am
Thanks for the help that link was useful. Will try bigger hammer and see how i go however it's almost time for a new plan me thinks
Post Posted: Fri Feb 19, 2010 12:30 am
Just remember what Stekky said in there.....just hit ya finger then start yelling and swearing and the part will get scared then undo :P
Post Posted: Fri Feb 19, 2010 12:31 am
you can otherwise pull the caliper, rotor, freewheeling hub and circlip that holds the driveshaft and undo the 4 bolts holding the stub axle on and pull the lot and put a betterer one on
Post Posted: Fri Feb 19, 2010 12:58 am
It came off after some wd and bigger hammer :) so now i just need new bearings which hopefully i can get tommorow Thanks for the help
Post Posted: Fri Feb 19, 2010 1:04 am
Pm Weaves off here he sells bearings cheap as chips :P :wink:
Post Posted: Fri Feb 19, 2010 1:39 am
He sure does, and is an absolute gentleman to deal with. Helped me out a fair bit with an issue I had with my coily POS :P
Users browsing this forum: No registered users and 172 guests
