It is currently Wed Sep 09, 2026 2:49 am
Post Posted: Sat May 22, 2010 11:36 pm
I am pretty sure I busted a CV at GH yesterday. I was already on the lookout for Heavy Duty CV's because I am going to install lockers.
So, Does anyone know of any sources for some good quality heavy duty CV joints for 08/09 Jimny?
I am also after some Urethane Panhard bushes, as I flogged out the front ones completely yesterday and ended up with only 30deg of steering. THAT was fun to drive home!
edit: I am told that I'd be better off just going a whole upgrade to Chrome Molly axle's and HD CV's!
Post Posted: Sun May 23, 2010 6:59 am
Did you end up recieving the stuff from me?
Post Posted: Sun May 23, 2010 7:57 am
Hi mate
Yeah i did, a week ago now I think. Sorry, I did mean to send an email to let you know. Do you have a RH guard?
Post Posted: Sun May 23, 2010 8:31 am
I do have the rh guard and i have cv's but still in the hubs.. Didnt have a star socket for the hubs..
Did you need cv's only or axle shafts as well?
May be a pain to post.
Post Posted: Sun May 23, 2010 9:00 am
I have an entire front diff assembly disc to disc which I can raid for a simple replacement, but I really want to upgrade the CV's and axles anyways.
Post Posted: Sun May 23, 2010 10:48 am
Is there a place that upgrades jimny cv's?
Next option maybe 1.3 wt diff, Bigger axles/cv's stock. Then upgrade with cromo's.
Post Posted: Sun May 23, 2010 12:30 pm
Kas suggested that today.
What is the track difference between Jimny and WT?
Post Posted: Mon May 24, 2010 12:18 am
Unsure. You may have to ask in tech.
Jimny's look wider than WT
Post Posted: Mon May 24, 2010 12:26 am
Wayne I am pretty sure that the Jimny is 1355 and the WT is narrower at 1300, but this can be sorted out with wider wheels
Post Posted: Mon May 24, 2010 1:38 am
Or would a set of wheel spacers suffice also?
Mitch.
Post Posted: Mon May 24, 2010 9:56 pm
I asked Tim today if he can check on HD axles and CV's.
Kas, I agree with the premise of going back to WT diffs and welding Jimny suspension brackets to it, but...
Sierras are now 15 years old and getting older, in the least. Jimny is still in production and can really only get more popular as time goes on. If I go the Sierra route, I have to outlay more money for diff assembly, fabrication of bracketing and reinforcing, spacers or rims, and possibly more.
I have this diff housing already reinforced, albeit that I have to refurbish it cos it leaks like a s sieve at the ball and weld. Peter is on the job.
Users browsing this forum: No registered users and 1 guest
