It is currently Sat Sep 26, 2026 2:16 am
Post Posted: Mon Jan 11, 2010 11:10 pm
My truck's motor is rather gutless and struggles to get anywhere near 90km/h. To maintain this speed I have to have the accelerator flat on the floor. The motor has only done 108,XXX km's and has been babied all it's life. The truck is stock apart from some 215/75/15's. Do I need to clean the carby out or have the tyres upset the gearing that much?
Post Posted: Mon Jan 11, 2010 11:15 pm
Same tyres as i run, and I don't struggle.... (G13BA though).
Still I would suggest that the performance is sub par, and the carby would be the place to start...
I want my old sig back :(
Post Posted: Mon Jan 11, 2010 11:21 pm
sounds like something is dead
Post Posted: Mon Jan 11, 2010 11:36 pm
A good tune would do it good
along with plugs leads and filters
Post Posted: Mon Jan 11, 2010 11:47 pm
If you replace 1 thing in the list of performace changing mods then you won't notice it, but if you do, plugs, leads, GT40 coil, oil+filter, air filter, fuel filter, and a can of carby cleaner down the body of the carby, it will feel atleast by the seat of your pants faster....
Post Posted: Mon Jan 11, 2010 11:54 pm
Check out that the throttle is fully opens when the pedal is flat to the floor.
With my mates sierra it wasn't opening fully and would only get to a top speed of about 90kph.. After we fixed this had no problem getting up
to 110 (that was with 31" tyres and using a gps not the dash)
Post Posted: Tue Jan 12, 2010 1:39 am
first thing......
VITARA CARBY!.......
Post Posted: Tue Jan 12, 2010 1:44 am
oh is a vit carby that good?
Post Posted: Tue Jan 12, 2010 2:38 am
First things first, do a compression check.
No amount of new leads, rotors, dizzy caps, carbs or EFI systems are going to do dick if you have low compression.
Post Posted: Tue Jan 12, 2010 2:42 am
pppfffttt compression........
all you need is........
Post Posted: Tue Jan 12, 2010 2:43 am
lol joe, beat me to it by >< that much!
Post Posted: Tue Jan 12, 2010 2:44 am
Hey Joe!
My 1.3 sierra makes no power. Do I just tip this 'NOS' product in my fuel tank?
Someone told me you add it to the wiper fluid, but I think they were having me on :?
:D
Post Posted: Tue Jan 12, 2010 2:54 am
Yep, fuel tank Fatzook. You gotta be quick with the fuel cap once you've emptied the bottle in but.....
Post Posted: Tue Jan 12, 2010 3:03 am
So thats what I have been doing wrong :D
Post Posted: Tue Jan 12, 2010 5:13 am
Is the engine a dog in all gears, or just runs out of puff at high speeds? Can you rev it to 5000-5500rpm in lower gears, or doesn't it get that far?
Post Posted: Tue Jan 12, 2010 11:27 am
Check secondaries are opening.
Post Posted: Tue Jan 12, 2010 7:30 pm
It has had a tuneup, new plugs and leads but it didn't make any difference.
303zuke: It'll get to about 4k in 2nd but after that it just runs out of puff :lol:
It'll rev to redline in neutral though.
Post Posted: Tue Jan 12, 2010 8:53 pm
X2
Look for the secondary vacuume actuator. Follow it's vacuume lines back to the carby. Try and blow through them as they are most likely carbon'ed up at the port where they enter the carb. If it runs outta puff at 4k then its most likely running on a single throat.
Dan
Post Posted: Tue Jan 12, 2010 9:01 pm
x3 on the secondaries.when my zuk was still 1.3 it flew with the first motor but had wrecked head,then with new motor was a dog up the road due to vaccuum lines being put on wrong by me :oops: :lol:
Post Posted: Tue Jan 12, 2010 9:15 pm
Dan
Where would I find this secondary vacuum actuator?
Post Posted: Wed Jan 13, 2010 5:48 pm
Bumppitty bump bump :lol:
Post Posted: Wed Jan 13, 2010 9:25 pm
If you're looking from the drivers side fender, the secondary vacuum actuator is the diaphram on the left side just under the auto choke hoses.
Post Posted: Thu Jan 14, 2010 10:21 am
Ooooooooook...
Post Posted: Fri Jan 15, 2010 2:25 am
Description fixed
But, if you can't figure it out from this description, then I'll take a stab that you won't know how to check it either. Maybe best to get a mechanic look at it.
Post Posted: Wed May 26, 2010 12:41 am
Thanks for your help guys, it'll sit on 110kph easy now 8O
Vehicle: 75 Cruiser
Post Posted: Wed May 26, 2010 12:43 am
you have a G13A in a truck? wholly crap, what kind of truck?
Post Posted: Wed May 26, 2010 12:47 am
Smartass...
Post Posted: Wed May 26, 2010 4:25 am
there is a 100 things it could be check your timing mine was running fine i gave it a bit of a thrash and it seemed to die in the ass and then checked the timing and it was way advanced maybe it slipped runns better now that is is set back to 10 :)
Post Posted: Wed May 26, 2010 4:56 am
Don't worry... All fixed now.
Post Posted: Wed May 26, 2010 5:10 am
So what did you fix/adjust?
Users browsing this forum: Google [Bot], sideways and 1490 guests
