It is currently Fri Oct 09, 2026 9:29 am
Post Posted: Tue Jun 15, 2010 3:21 am
I've been searching. Can't remember or find who did it.
Unsure if they used a roctoy ring also. Cut out floor and re plated etc.
All i remember is that the swb sierra was red.
Halp!
:wink:
Post Posted: Tue Jun 15, 2010 3:35 am
i can remember something about it 2 they used a rock toy but had to cut part of it or i might be thinking of another one not sure
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Tue Jun 15, 2010 6:19 am
i will soon. I can post up tech if you like.....
Post Posted: Tue Jun 15, 2010 6:24 am
I have done one, didnt use a ring and replaced the stock bushes with 2inch body blocks and an 8mm spacer. Has lifted the case above the rails but I still manage to hit it on rocks :roll: Was worth doing though.
Post Posted: Tue Jun 15, 2010 7:31 am
I'm not sure who did what your talking about, but do remember seeing pics :?
Mine is only slightly lifted, and slightly "clocked". But at least this shows where the roctoy ring has to be "modified" if you want to know...
Clearance Hole Technology :P
Post Posted: Tue Jun 15, 2010 8:44 am
Mine had the transfer with roctoy ring lifted to allow a flat belly plate. Might be between 1-2". Floor was cut away to make it fit but not really re-plated :oops:
Member of C.O.R 4x4
Post Posted: Tue Jun 15, 2010 10:40 am
my zook has a 2" body lift and a roctoy ring fitted.
last weekend i lifted the case with some 65x35m rhs which didnt get it above the chassis rail but it did get it up just above the cross member that the right front transfer mount runs on.i have 6.5mm of clearance now at the tp of the tunnel and on the drivers side where the ring goes.
i am going to mark the ring,drop the case out and trim the ring up so i can go to 40mm or 50mm lift then its only my exhaust left and i can make a flat belly skid.Am trying to avoid belting the tunnel but i might tweak it a little.
SO.......i would think the ring would need a heap of trimming or the tunnel a heap of bashing????
Post Posted: Tue Jun 15, 2010 12:40 pm
I believe it is rons zook. I'm not sure if he's on az but he's on outers, go's by the name of ronoor... His zook is a red swb softop with a 2 inch suspension lift with a virtual lift done on the guards. He's got a roktoy ring fitted with a transfer case lift kit. He had to cut part of the tranny tunnel and raise it so it all fits... Hope that helps...
Post Posted: Tue Jun 15, 2010 12:53 pm
Thanks guys! Just plans for my lwb.
In my swb I have a 2" trans lift with 2 " bl with roctoy ring and bashing..
Its a different story with no BL and 2" Translift with roctoy. I know she will need cutting/not afraid. I was just worried if i will need to move the seat rails for more room..
I want a flat plate underneath, and modifying the crossmember so it is dead flat.
You should see my swb crossmember! :lol:
Vehicle: Sierra
Post Posted: Wed Jun 16, 2010 7:40 am
Pics?
Post Posted: Wed Jun 16, 2010 9:49 am
You have enough room on the drivers side to raise the floor up to the same hieght as the top of the tunnel but you are fairly limited on the passenger side. I went a bit overboard on the passenger side cut out and had to raise the passengers seat by about 35mm to clear the new floor hieght, you could possibly get away with raising the floor by around 15mm. Not sure about clearing the ring though. My crossmember looks like its been molestered by a cement mixer too :lol:
Post Posted: Wed Jun 16, 2010 12:47 pm
Thanks. So i may have to lift the seat mount/rail.. Hmm...
May as well just make up the passenger side mountings same as drivers side!
Pics tomorrow. With lwb update in buildup ;)
Post Posted: Sat Jun 26, 2010 6:13 am
Tim,
Here's how much had to be cut out of mine to make it fit. Transfer with roctoy ring lifted to allow flat belly-plate, NO body lift.
I've got a job ahead of me to box this in :roll:
Member of C.O.R 4x4
Post Posted: Sat Jun 26, 2010 8:38 am
At least the tailshaft is covered!
That hole looks waaaaaayy bigger than i imagined. But also looks too big!
There is no front seat rail? it runs from the sill to the tunnel, you can see where the welds were.... How are your seats mounted?
Users browsing this forum: No registered users and 251 guests
