It is currently Sun Oct 04, 2026 10:23 am
Post Posted: Fri Jul 16, 2010 2:43 am
Is it possible to fit a transfer case with a high ratio to a 2003 jimny with a m13a motor?The reason I ask,is I have just had a s/h transfer case fitted & while driving home I was doing 100km/h @ 4,000rpm according to my speedo/tacho,but a friend who was following says he had to do 120km/h to keep up.I am running 215/75x15 BFG AT's which would account for approx 5km/h.I won't mind if it is geard up a bit,as i've always thought it needed another gear.
Any Thoughts?
Post Posted: Fri Jul 16, 2010 2:44 am
Tyres.
Post Posted: Fri Jul 16, 2010 2:46 am
I'm assuming that the apeedo drive on a Jimny is on the output of the T-Case like a Sierra so changing ratios won't make a difference to accuracy of the speedo reading...
I want my old sig back :(
Post Posted: Fri Jul 16, 2010 4:13 am
maybe you speedo needs to be adjusted?
my 215's put my speedo out by about 10km/h.
Post Posted: Fri Jul 16, 2010 8:31 am
Go down to Jaycar, get yourself a speedo adjusting kit and a soldering iron. once fitted you can adjust the speedo to be correct.
goodluck
Users browsing this forum: No registered users and 228 guests
