It is currently Thu Oct 01, 2026 10:54 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Vehicle: Suzuki Sierra
Post Posted: Wed Aug 04, 2010 3:20 am
My 1.6 Blaeno motor (with Jimny auto) has a miss/hesitation under load on accelleration.
The check engine light comes on when this happens. The diagnostic tool we have here won't talk to it.
The TPS is new, fuel pressure is OK, under light load/accelleration drives fine. when it gets past that particular load spot it also drives fine.
Any ideas?
Post Posted: Wed Aug 04, 2010 3:21 am
Oh, it's a twin coil pack motor if that makes any difference.
Builder of street legal bacon sandwiches
Post Posted: Wed Aug 04, 2010 3:23 am
do you have a VSS fitted?
Post Posted: Wed Aug 04, 2010 4:02 am
Yes has VSS
Post Posted: Wed Aug 04, 2010 4:06 am
have you inspected the coil packs and stems?
Post Posted: Wed Aug 04, 2010 4:11 am
Could be a MAP sensor issue.
Lil Foot!
Post Posted: Wed Aug 04, 2010 4:20 am
That's what we're looking at now. $306 + GST trade 8O trying to make sure that's what it is first.
It has spark, runs fine at revs/no load. Will check with the auto elec out the back to see what he's done there.
Post Posted: Wed Aug 04, 2010 4:38 am
$306!!! Get stuffed!!!! Can ya show us a pic of it? Even better does anyone have the specs on the sensor ie voltage output at idle (high vacuum) and WOT (no vacuum). There will most likely be alot cheaper option like possibly a GM 1bar sensor if the outputs match.
Dan
Lil Foot!
Post Posted: Wed Aug 04, 2010 5:18 am
Hey Mate,
It's a Denso 0798004990
5V
The only other number on it is 81AO
Post Posted: Wed Aug 04, 2010 5:57 am
you should be able to short out the check connector the old fasioned way, if it is still on the loom.
Post Posted: Wed Aug 04, 2010 6:05 am
The problem is that the check engine light only comes on when it's starving/hestiating/dying then switches off when it passes that point.
A history code would make life easy. Unfortunately life isn't so easy.
Vehicle: 4wd
Post Posted: Wed Aug 04, 2010 6:18 am
Is it just one miss or a series of misses?
Watch out or you'll get sued.
Post Posted: Wed Aug 04, 2010 7:39 am
My Baleno motor kept dropping cylinders and missing under load, was caused by water in the sparkplug hole. Try blowing all the holes out, spraying a little CRC down there and reinstall coilpacks.
Post Posted: Wed Aug 04, 2010 7:44 am
Yeah, pull the coil packs and check holes for moisture. Also look for burn marks or tiny holes on the stems.
Post Posted: Wed Aug 04, 2010 8:01 am
That's not normal - Check engine should stay on once it's been lit.
Camshaft position sensor? That's the magic Jimny/Baleno cure all :D
Post Posted: Wed Aug 04, 2010 9:27 am
X2 :P
Eng light "should" reset if the battery was disconnected tho.
Post Posted: Wed Aug 04, 2010 9:32 am
And that's the strange bit.
Post Posted: Wed Aug 04, 2010 9:37 am
If, & I say "if" the cam/crank angle sen is braking down & not firing the coil's, the o2 sen could be throwing the light but not a code, some fault's take 6 cycle's to throw a code.
but I doubt it..
Post Posted: Wed Aug 04, 2010 10:07 am
usually coil pack or coil pack probe , but doesnt normally throw a check engine light ..
if you are using the baleno engine bay fuse box you can jump B&D to manually get the code in DIAG1 , if you dont have this , you can ground out the B16 wire from the ecu , it is a violet wire with a yellow stripe
Post Posted: Wed Aug 04, 2010 10:33 pm
So in no particular order:
-New TPS
-Checked, cleaned plugs and leads. Clean and no moisture, no noticable holes/burns
-Checked as best as possible for vac leaks
-Cleaned throttle body
-Checked cam sensor - no marks/noticable wear
-Checked fuel pressure
-Checked air filter
At a loss I've just ordered
Cam sensor
MAP sensor
We'll see how it goes.
Post Posted: Wed Aug 04, 2010 10:36 pm
what vss you running? early vit or baleno/jimny?
Post Posted: Wed Aug 04, 2010 10:44 pm
I believe it is Vitara.
You can however get the engine light on without the car even moving which ruled out the VSS and any gearbox issue. The light comes on even while in neutral.
The starve only happens when the light is on driving under load.
Thanks guys for your help so far. All has been taken onboard and is greatly appreciated.
Post Posted: Thu Aug 05, 2010 2:35 am
This FARKING car!!!!!
Changed cam sensor, no change
Changed MAP, no change
Changed coil packs one at a time, no change
Post Posted: Thu Aug 05, 2010 2:44 am
give it to me? 8)
Post Posted: Thu Aug 05, 2010 4:16 am
give it to me? 8)
Everything is for sale :D
Just went and topped up the tank with some fresh premium unleaded. No difference.
Driving back pulsing the throttle it seems to drive OK with no light :?:
Post Posted: Thu Aug 05, 2010 5:22 am
Fuel pressure reg swapped out. Still the same.
Post Posted: Thu Aug 05, 2010 7:02 am
jim, if you have the tacho circuit hooked up to the standard sierra unit disconect it and see if it makes a difference. if it does you will have to graft a jimny/ baleno/ ignis unit in.
Post Posted: Thu Aug 05, 2010 7:41 am
Doesn't have a tach from memory (It has a commercial 1.3 instrument cluster - no tach)
Post Posted: Thu Aug 05, 2010 11:19 am
Cheers Joe.
But yes, Steve is correct, no Tacho.
Have pulled the computer out, no visable shorts/burns.
The previous owner tells me that the car pretty well stalled and then required a jump start. From then on the issue began. Not sure if that might give anyone some ideas.
The hard thing is that it was running right before hand. :?
Post Posted: Thu Aug 05, 2010 11:46 am
fuel pump relay on the fritz? :?
Users browsing this forum: No registered users and 100 guests
