Joined: Sun Nov 30, 2008 10:30 pm Posts: 1213 Location: SW Bris
Posted: Fri Aug 06, 2010 7:18 am
Ok just in case I need to source a starter motor.
I have a g1.6b vit block Carby and a 1.3 sierra head with 1.3 gearbox with adapter plate.
Do I need the 1.3 sierra starter or a 1.6 vit starter?
Does the adapter plate make anydifferece to the mounting of the starter?
Pretty sure ya need a 1.6 one. But you can use a 1.3 one if you grind a bit off it to make it fit. However I don't know which bit you have to grind off lol
Posted: Fri Aug 06, 2010 8:47 am
Some people grind the block...scary!
I machined down my startermotor. The main body outer on the lathe, and linished the mount and top cover to suit. Works fine. But i have access to machinery 4 free..
Users browsing this forum: Google [Bot] and 98 guests
