| Author |
Message |
Mistaria81
Joined: Wed Oct 07, 2009 10:30 pm Posts: 175 Location: mango hill, Queensland
Vehicle: 2004 KJ jeep cherokee
 Posted: Sun Aug 08, 2010 6:24 am |
hi, all. Been a long while since I've posted. Quick question. currently have a widetrack 2l vitara with the small prob of the engine having been destroyed by the previous idiot, erm owner. Am I able to put a 1.6 efi in no hassles or is it better sourcing another 2l engine?
any advice please.
BUZOOKA
Joined: Sun Aug 30, 2009 11:30 pm Posts: 2659 Location: hobart tasmania
 Posted: Sun Aug 08, 2010 6:34 am |
there is a difference in tracks between the vits aswell ?
_________________ -indebt 4x4 club-
nav 32s n winch cust rear
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Sun Aug 08, 2010 6:45 am |
The 2 litre is a different series motor (J series) than the 1.6 (G series) so its far from a straight bolt up. As its also a backwards step, I wouldn't go to the hassle...
_________________ I want my old sig back
atari4x4
 Posted: Sun Aug 08, 2010 6:49 am |
BUZOOKA wrote: there is a difference in tracks between the vits aswell ?
hence why he called it a widetrack vitara.... orsam tech buzztroller, hurry up & join pootrol4x4.com
there are quite a few things that would make the conversion back to 1.6 a bit of a headache, for starters the gearbox is different, the engine mounts are different, the ECU & wiring would be a big job...
get another J20a or even the H20a or H25a V6's as the loss of power with the 1.6 would suck + the legalities of getting an older engine engineered in a newer vehicle could be a challenge.
morpheus
Joined: Mon Oct 06, 2008 10:30 pm Posts: 689 Location: Adelaide
 Posted: Sun Aug 08, 2010 7:04 am |
yeah look for another 2L. i have a 1.6 and i'd love more power..
Fatzook
 Posted: Sun Aug 08, 2010 7:08 am |
The new SX4 J20's are about 1500-2500 from the wreckers.
If you run your inlet manifold, You should be able to get it up and running again. with a very low km's motor.
Peter
steak_knife
 Posted: Sun Aug 08, 2010 7:13 am |
is it a 4 or 6???
Mistaria81
 Posted: Sun Aug 08, 2010 7:56 pm |
thanx guys, thats all I needed to know. I'll start looking into another motor or maybe the v6.
_________________ If at first you don't suceed... lower your standar
steak_knife
 Posted: Sun Aug 08, 2010 8:53 pm |
Mistaria81 wrote: thanx guys, thats all I needed to know. I'll start looking into another motor or maybe the v6.
So it's a 4 then??
if it is a 4 & you go 6 I may be interested in the eng, box, harness & loom out of your car.....
Mistaria81
 Posted: Sun Aug 08, 2010 9:28 pm |
yea it was a four, it now a 20 pieces
BUZOOKA
 Posted: Sun Aug 08, 2010 9:34 pm |
atari4x4 wrote: BUZOOKA wrote: there is a difference in tracks between the vits aswell ? hence why he called it a widetrack vitara.... orsam tech buzztroller, hurry up & join pootrol4x4.com there are quite a few things that would make the conversion back to 1.6 a bit of a headache, for starters the gearbox is different, the engine mounts are different, the ECU & wiring would be a big job... get another J20a or even the H20a or H25a V6's as the loss of power with the 1.6 would suck + the legalities of getting an older engine engineered in a newer vehicle could be a challenge.
gus that wasnt tech i asked a question aswell .. of cant u see the lil question mark at the end ..
atari4x4
 Posted: Mon Aug 09, 2010 12:25 am |
BUZOOKA wrote: atari4x4 wrote: BUZOOKA wrote: there is a difference in tracks between the vits aswell ? hence why he called it a widetrack vitara.... orsam tech buzztroller, hurry up & join pootrol4x4.com there are quite a few things that would make the conversion back to 1.6 a bit of a headache, for starters the gearbox is different, the engine mounts are different, the ECU & wiring would be a big job... get another J20a or even the H20a or H25a V6's as the loss of power with the 1.6 would suck + the legalities of getting an older engine engineered in a newer vehicle could be a challenge. gus that wasnt tech i asked a question aswell .. of cant u see the lil question mark at the end ..
Starting a sentence with "There is" like you did makes it a statement if you'd started it with "Is there" it would make it a question. The two make what you wrote read in two completely different ways.
For the question mark at the who know's what that could have been..... maybe 1/2 a smiley ?
Now back to tech, the current evolution of the J20a in the SX-4 is now pumping out around 110kw, up from the 95-97kw in the Vitara, I wonder what they've done to get the extra power? ECU Tuning or does it have variable valve timing?
BlueSuzy
 Posted: Mon Aug 09, 2010 12:44 am |
The new sx4 will have VVT, So a change of the wiring will be needed to suit the ecu.. The motor should bolt up, in theory. Practical however, who knows..
I though all the suz small cars would of used 'M' Series motors..swifts, jimnys etc
Fatzook
 Posted: Mon Aug 09, 2010 1:08 am |
BlueSuzy wrote: The new sx4 will have VVT, So a change of the wiring will be needed to suit the ecu.. The motor should bolt up, in theory. Practical however, who knows..
The bolt pattern looks the same, but you would need the vit sump and pickup. The intake manifod is almost unusable in a vit though. And I'm not sure if the J20 vit manifold would swap onto the SX4 head...
Here are some pics of a VVT J20 from 2009 SX4.
BlueSuzy
 Posted: Mon Aug 09, 2010 1:24 am |
Jeez. Whens the cam cover gooing to plastic.. oh, plastic block would be awesome too...
neofitou
Joined: Wed Mar 24, 2010 10:30 pm Posts: 1088 Location: Melbourne
Vehicle: 00 Jimny, 63 Haffy
 Posted: Mon Aug 09, 2010 1:45 am |
BlueSuzy
 Posted: Mon Aug 09, 2010 1:53 am |
HAHAHAHAHA oh.....
losfer
 Posted: Mon Aug 09, 2010 8:54 am |
one thing to note , the conversion from the j20 from a sx4 is not possible if you have a sq420 vitara , it may fit in the jb420.
the reason for this is that the cam position sensor is driven off the cam (eg dizzy type) whereas the sx4 engine doesnt have provision to bolt the cam position sensor in the head. I know this as i wanted to put the j20 from the sx4 in a j18 gtx baleno and this is what was stopping me ..
steak_knife
 Posted: Mon Aug 09, 2010 9:09 am |
BlueSuzy wrote: Jeez. Whens the cam cover gooing to plastic.. oh, plastic block would be awesome too...
 The new 2.4's..
steak_knife
 Posted: Mon Aug 09, 2010 9:11 am |
losfer wrote: one thing to note , the conversion from the j20 from a sx4 is not possible if you have a sq420 vitara , it may fit in the jb420. the reason for this is that the cam position sensor is driven off the cam (eg dizzy type) whereas the sx4 engine doesnt have provision to bolt the cam position sensor in the head. I know this as i wanted to put the j20 from the sx4 in a j18 gtx baleno and this is what was stopping me ..
The JB run off the back of the crank in the bell housing..
losfer
 Posted: Mon Aug 09, 2010 9:22 am |
steknig wrote: losfer wrote: one thing to note , the conversion from the j20 from a sx4 is not possible if you have a sq420 vitara , it may fit in the jb420. the reason for this is that the cam position sensor is driven off the cam (eg dizzy type) whereas the sx4 engine doesnt have provision to bolt the cam position sensor in the head. I know this as i wanted to put the j20 from the sx4 in a j18 gtx baleno and this is what was stopping me .. The JB run off the back of the crank in the bell housing..
so does the sx4 , the part number is the same for a jb vitara crank and the rw sx4
steak_knife
 Posted: Mon Aug 09, 2010 9:24 am |
I've looked at that a couple of time's, found no real solution tho, just looked..
