It is currently Sun Oct 11, 2026 11:39 am
Post Posted: Wed Sep 01, 2010 11:26 am
Until 2 days ago my lights worked fine. Now i have no low beam, high beam and parkers work. Any suggestions? Thanks. ( its a 91 Sierra)
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Wed Sep 01, 2010 11:32 am
Blown fuse??
Post Posted: Wed Sep 01, 2010 11:34 am
Nope, checked that.
Post Posted: Wed Sep 01, 2010 11:35 am
Globes??
Had one go and people didnt notice till the 2nd one has gone..
Vehicle: 96 LWB Vit
Post Posted: Wed Sep 01, 2010 11:38 am
Last time that happened to me it was in the switch.
Buddies.
Buddies
I can't leave well enough alone....
Post Posted: Wed Sep 01, 2010 11:40 am
Not globes either. Im thinking its the switch or something up in there not connecting properly......? Will have to pull it all out in next few days i think
Vehicle: MY2019 Jimny
Post Posted: Wed Sep 01, 2010 11:45 am
Checked the other fuse?
Post Posted: Wed Sep 01, 2010 11:47 am
earths down near the headlight both sides screwed down tight?
Post Posted: Wed Sep 01, 2010 12:36 pm
Whip out the multimeter mate, I'd be checking all the cables and see if your getting any voltage running though the cable.
helloo
Vehicle: '94 suzuki maruti
Post Posted: Wed Sep 01, 2010 2:03 pm
x2. best place to start IMO. instead of working out what isnt working, work out what is.
Post Posted: Wed Sep 01, 2010 8:18 pm
cmon guys you should all know this one by now
let me guess the high beam dash light lights up on low beam and its all gone strange?
4th fuse in from the left in the top row is blown, it will test ok in there though you need to pull it out and look at it
if its not that one its close to it, cant remember its exact location
Vehicle: Suzuki
Post Posted: Thu Sep 02, 2010 12:58 am
What Royce said.
If its continually blowing then check your alternator wire is connected and good.
It was continually blowing for me and I found that my problem was that my alternator became disconnected from the loom and when I braked when the lights were on it would blow that fuse..
Post Posted: Sat Sep 04, 2010 11:11 pm
Its not the fuses. Pulling the switch out today. Wheres the best place for replacement parts?
Post Posted: Sat Sep 04, 2010 11:15 pm
Switch// Send want33's a PM
Post Posted: Sun Sep 05, 2010 2:58 am
im gettin power to all 3 wires in the light? This cant be right. Even when the light switch is off, im getting power. Has to be switch rite?
Post Posted: Sun Sep 05, 2010 3:01 am
they are negative switched, power there all the time and it witches the high or low beam filamnet
unplug both lights and try again, youll have power on one vertical pin only
did you pull the fuse out and test it by itself or not?
Post Posted: Sun Sep 05, 2010 3:02 am
yours must be possessed by jebus.... suzuki's are negatively switched.
Post Posted: Sun Sep 05, 2010 5:05 am
ok. i unplugged both lights, have power to one virtical pin as you said. So why is low beam not working? Switch? Hi beam and parkers work fine.
Post Posted: Sun Sep 05, 2010 5:06 am
now with both plugs unplugged see if you have earth on the 2 horizontal pins ONLY
Post Posted: Sun Sep 05, 2010 7:03 am
thanks heaps for your help. Turned out to be a bad earth bad earth.
Post Posted: Wed Jan 25, 2012 6:37 pm
I had no low beam this morning, not the fuses, guess I gotta check the earths.
Users browsing this forum: Google [Bot] and 266 guests
