It is currently Tue Nov 03, 2026 7:02 am
Post Posted: Sat Aug 28, 2010 7:55 am
Ok well since i gave my rear bar some love i have been starting to work out what i wanted.
also had a bonus.. after i had drawn up basicly what i wanted, i relised that i already owned a bar that looked nearly what i wanted and just needed some 9inch love and new mounts etc
so some pics i started today and removed my old rear bar, wow not much holds them on! and started to take to the big girl.. i do inted on getting it powder coated once it is done 2.
Started with..
removed and started on new bar.
this side will be plated in etc but u get the point.
i still need to remove old mounts, make new ones, recover points, haymon Reece hitch, fill in holes for ghey tail lights, find round tail lights that i like and make a mount somewhere for reversing light.
Post Posted: Sat Aug 28, 2010 8:43 am
nice, i will be doing the same thing in the coming months.
take lots of pics :lol:
Post Posted: Sat Aug 28, 2010 9:01 am
as always..
i will add the rear bar is actually a zook one lol..
Post Posted: Sun Aug 29, 2010 5:34 am
more done..
i need a mig! grr..
i might put in a order for some slim line numberplates to.. still a bit more chopping of body to be done 2.
Post Posted: Sun Aug 29, 2010 5:37 am
Looks good matey, would look better if it sat closer to the bottom of the rear door :wink:
Post Posted: Sun Aug 29, 2010 5:51 am
yeah it will..
that was only just proped up so i could get a ruff idea of what it was going to look like :D
and i like it!
also did u add me to face book?
Post Posted: Mon Aug 30, 2010 8:03 am
Nice work, good to see you are giving it a go yourself.
Post Posted: Mon Aug 30, 2010 8:52 am
yeah PJ i have never been scared to make stuff! i built my front bar 2. and everything elce just a matter of ordering my tail lights atm and finish monts etc.
Post Posted: Sat Sep 04, 2010 5:13 am
this is the 500mm of 100x8mm flat bar (actualy 2.5mtrs off 100x10mm love buying stuff from my old work)
had to grind a bit out and clean a bit up but fits up nice
Removed some junk that is not needed any more, the points will be mounted with 2x10mm 8.8s with crush tube inbetween the chassis.
Haymond reece mount in, needs to have center hole drilled, and shortened. i am going to try to keep the amount hanging out of the bar to a minimum
might try get a bit more done tomorow but i am putting it off till i get my new mig!
Post Posted: Sun Sep 26, 2010 10:28 am
Ok updates on bar. i finished the mounts, cut out for the LED tail lights, and tacked it all up.. haymond reece recever is done 2
pics
it has a pretty good look 2 it imo. it is currently at the welders place and should be done buy thrusday/friday
Post Posted: Wed Sep 29, 2010 7:48 am
Post Posted: Wed Sep 29, 2010 12:24 pm
i want one
Post Posted: Wed Sep 29, 2010 12:50 pm
its pretty simple i have made all of this bar the pro welding with a $50 drill, some hole saws.. (good ones but meh) a 4 inch and a $50 stick welder!
Post Posted: Wed Sep 29, 2010 12:55 pm
jonno_racing wrote:
some hole saws.. a 4 inch
you must really love it
simple, effective and easy.
It looks the goods,
I dont want to be a negative nancy, so ill keep my mouth shut.
Post Posted: Wed Sep 29, 2010 12:59 pm
kind of untill u ask it to cut up and shape 10mm plate.
Post Posted: Thu Sep 30, 2010 11:08 am
well i can hapily say my rear bar is DONE! :) just need to fit her up and wire lights!
Post Posted: Thu Sep 30, 2010 11:09 am
Constructive critisam or piss take?
Vehicle: SWB Vit & LWB GV
Post Posted: Thu Sep 30, 2010 10:10 pm
What's the edge distance of the hole for the reese hitch bolt to end of SHS and what size is the hole?
minimum edge distance should be 1.5x bolt hole.
stock as a rock
Post Posted: Thu Sep 30, 2010 10:12 pm
That does look good... Mount it up Jonno!!!!!! :P
Post Posted: Fri Oct 01, 2010 8:58 am
X2 it has come up very nice Jonno Good Work :wink:
Bitumen...Another waste of public funds!
Post Posted: Fri Oct 01, 2010 9:27 am
Thanks guys. i am happy with it 2! cant wait to get her out and test it out!
i stole a few ideas off yours bog i liked it that much!
2 be honest mate i have no idea atm. i think the hole is 14 or 16mm and the gap is 25mm from memory! to be honest tho i would be much more concernd about it tareing the bar out of the chassis before the end out of the recever
Vehicle: chick magnet coily
Post Posted: Wed Feb 15, 2012 6:03 pm
was it verry hard to wire up new lights?
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Thu Feb 16, 2012 3:08 pm
Mate, that's sweeet! Looks real nice. I like your cutting and shutting work, it gives it a very nice shape.
Users browsing this forum: Google [Bot] and 13 guests
