It is currently Wed Jul 29, 2026 3:49 pm
Post Posted: Sat Nov 13, 2010 8:02 pm
Hi,
Can somebody please tell me why the drivers side tyre scrubs now when I hit bumps since I got the ARB bar fitted please ?
Myself (and others) have looked at both sides of the car and we can't see any differences. I only have slightly bigger tyres fitted and also just the OME spring/shock (40mm lift) and a 15mm spacer.
I've seen a couple of threads from a while back where people talk about chopping the ARB bar ??? Seriously ? If this fixes the issue, would anybody have a pic of exactly where they cut it please ?
Cheers,
Guy
 Profile YIM
Post Posted: Sat Nov 13, 2010 8:16 pm
what car you have mate?
Post Posted: Sat Nov 13, 2010 8:22 pm
2010 Jimny.
Thanks
 Profile YIM
Post Posted: Sat Nov 13, 2010 8:28 pm
cool... got any pics of where it touches?
Post Posted: Sat Nov 13, 2010 9:43 pm
The right tyre only scrubs when I hit a good bump with the tyres turned to the right. My left tyre won't scrub no matter how big the bump is and if I've got it turned left or right.
The wheels are perfectly aligned.
There looks to be a fraction less space for the right tyre when looking side on compared to the left...
I'll take a couple of photos soon ant put them up.
 Profile YIM
Post Posted: Sat Nov 13, 2010 10:11 pm
He mate i know this will sound silly but have you got your back springs in on the right side?
DM90was having the same problem untill we swaped the springs over then it was all good
Post Posted: Sat Nov 13, 2010 10:39 pm
DM90was having the same problem until we swapped the springs over then it was all good
I don't know...ARB put them in.
Is there a mark on them that can be seen when lying under the car ?
 Profile YIM
Post Posted: Sat Nov 13, 2010 10:44 pm
Yeah there is a mark on them but i can't remember what it is :roll: :oops:
Have a look at the springs and see if there is L and R stickers on them
Does your car lean to one side more then the other?
Post Posted: Sat Nov 13, 2010 10:58 pm
i had a mate chop the sides of my bullbar back to stop the tyres scrubbing. dosent loook any diff and it dosent scrub anymore.
Post Posted: Sat Nov 13, 2010 11:07 pm
Your running 235/75x15s though aren't ya?
Post Posted: Sat Nov 13, 2010 11:20 pm
It will onlt touch on one side because the front of a jimny has a panhard rod, which locates the axle left to right. As you have a small suspension lift, the axle will be getting pulled towards the RHS of the car a little creating different clearances on the left and right had side of the car.
It's why people fit adjaustable pahrad rods - to centre the axle under the car once it has been lifted.
Post Posted: Sat Nov 13, 2010 11:58 pm
x2 it's not much but it might do it?
i have the 40mm ome lift on 215's and they are fine. maybe the spacers put it out that little bit more?
but then again your only running 215's they shouldn't scrub.
i would check the rear spring thing.
not really helping here am i :(
Post Posted: Sun Nov 14, 2010 12:26 am
I'll check the rear spring...
Thanks everyone.
(The spacers were only put on the front of the vehicle to counteract the weight of the front bar.)
 Profile YIM
Post Posted: Sun Nov 14, 2010 1:07 am
I had the same problem... Longer springs up the front did the trick.
09 Jimny Sierra Limited Edition
Post Posted: Sun Nov 14, 2010 1:45 am
check the rear springs, get under there and have a look, they have labels, A & B, one is longer then the other and goes on the drivers side.
ya also gotta take into account the weight of the driver, its always over the front right tyre,
i will be getting some spacers soon to stop this, if not will be cutting the ARB bar, there is a lip on the inside, taking that off should do the trick.
Post Posted: Sun Nov 14, 2010 8:29 pm
30x9.5 bighorns.
Post Posted: Wed Dec 08, 2010 6:28 am
Just got back to this...finally
The car doesn't seem to lean.
I got under the car to see the labels, but they are covered in dirt and I couldn't get my fingers in the springs to wipe them clean (the labels were toward the inside of the spring) I'll wait until i wash everything underneath...I I get a mate with skinnier fingers to have a look.
I might get an adjustable panhard rod anyway and see if that helps.
Thanks all.
Guy
ps. don't lie under car just after you have just drunk 750 mls of IceBreak...trust me...it comes back up pretty quickly. :-(
 Profile YIM
Users browsing this forum: No registered users and 778 guests
