It is currently Fri Jul 24, 2026 11:19 pm
Post new topic Reply to topic  [ 102 posts ]  Go to page Previous  1, 2, 3, 4  Next
Vehicle: 85 SJ413
Post Posted: Tue Mar 02, 2010 10:58 pm
Polar_Bear wrote:
in other words, i'd need a set of these
http://cgi.ebay.com/ebaymotors/1990-199 ... ccessories
Yep, thats the one. Note you also need the Mitsi brake hose and banjo fitting that bolts to it, but that shouldn't be hard to get.
Here are some more pics of the caliper for those trying to find them at wreckers.
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Tue Mar 02, 2010 11:32 pm
These look very similar to magna calipers
Post Posted: Tue Mar 02, 2010 11:37 pm
Magna calipers
Post Posted: Wed Mar 03, 2010 12:26 am
You need one of them & a left one, thay are different side to side.
thankyou captain obvious! :youdaman:
Go Hard, Trailer Home
Post Posted: Wed Mar 03, 2010 12:29 am
:P :roll:
Vehicle: 98 Maruti
Post Posted: Wed Mar 03, 2010 5:25 am
i would be extremely keen as iv being have a pile of rear brake drum problems on my SWb GV with the 1.6. so much so iv swap the complete hub from a 96 model vitara on. cheers to Mugwui for sorting me out with them
Post Posted: Thu Mar 04, 2010 2:55 pm
they look alot like ford corsair too.
Post Posted: Mon Mar 08, 2010 6:00 pm
corsair rebadged/styled = fwd pintara.
Alot of people use the pintara calipers.
Post Posted: Sat Nov 13, 2010 10:03 pm
I'm saving up and adding this kit to the list.
Best thing I ever did to my Sierra was rear discs (from Pintara)
Can't risk the cheaper LowRange, no hand/emergency brake type kit.
Post Posted: Mon Nov 15, 2010 8:08 am
Mines a 93 LWB
I assume kit will still fit same as a SWB
Vehicle: 85 SJ413
Post Posted: Mon Nov 15, 2010 8:22 am
christover1 wrote:
Mines a 93 LWB
Correct. Only exception is the later 96-97 models that have the wheel studs in the axle rather than in the drum, although I have just made some trial brackets for these too...
Ben
Post Posted: Mon Nov 15, 2010 1:20 pm
how much better are these compared to the standard drum brakes(like pros and cons)
and how long would the job be to install if i had a mechanic (just finished apprenticeship)
helping me to do it?
screwdriver's on ur head impale DropBears :)
Vehicle: 85 SJ413
Post Posted: Mon Nov 15, 2010 8:37 pm
Rear discs give better pedal feel than drums. If you drive in mud the pads will last much much longer than drums, and require much less maintenance. They also work when wet / muddy, and the handbrake actually works.
It only takes a few hours to install - everything is bolt on.
The guy who ran my first test kit over here said this about them:
"One of the best mods done to the truck! Awesome pedel feel never need to touch the brakes other than to change pads and all 100% reversable as it all bolts on (no welding or cutting). Highly recommended"
Ben
Post Posted: Mon Nov 15, 2010 8:52 pm
I just spent all arvo cleaning the mud out of my Vitara rear drums,
to get my brakes to work.
Drums and shoes are less than 10 months old,
and are both badly worn and scored.
Only driven one bog hole since I put new brakes in for rwc.
Putting rear discs on my old Sierra saved me a fortune,
and saved on frustration.
Here in Aus we must have a working hand brake, separate from normal brakes (emergency)
So a lot of other kits sold on the net are not suitable,
as they don't include a hand brake.
Vehicle: 85 SJ413
Post Posted: Mon Nov 15, 2010 10:07 pm
Yup. Conditions here are pretty similar to Victoria. I have gone through a set of brand new shoes in 1 day after a trip through lots of sandy clay bogs and a 40km drive home. After changing to discs, the pads last long enough that I can't remember when I last changed them.
The handbrake also works surprisingly well.
Ben
Vehicle: 96 LWB Vit
Post Posted: Mon Nov 15, 2010 11:44 pm
I would be 'VERY' interested in a late model kit.
I take it this is a late model axle?
Buddies
I can't leave well enough alone....
Vehicle: 85 SJ413
Post Posted: Tue Nov 16, 2010 8:14 am
Yes, thats the one. The kit for the later axle does not have a disc adaptor as the disc fits directly on the axle, and the brackets are different to suit the offset.
Ben
Post Posted: Tue Nov 16, 2010 9:41 am
sweet well if i get a vit which is more than likely ill be buying the kit within the first month of getting my car thanks for the info
Post Posted: Tue Nov 16, 2010 9:59 am
Ive got the day off tomorrow, i'm gonna go see what calipers i can find.
Post Posted: Tue Nov 16, 2010 10:24 am
u-steal-it had a vr4 galant in stock when they address...now they've moved i dunno if they still have it :?
Post Posted: Tue Nov 16, 2010 10:39 am
They dont have a 3rd of what they had at the old place.
I'll go have a squiz though.
Post Posted: Tue Nov 16, 2010 11:01 am
there is that mitsi wrecker that was around the corner.
Post Posted: Tue Nov 16, 2010 11:24 am
Yeah goin in there :wink:
Post Posted: Wed Nov 17, 2010 12:06 am
Didnt need to go to mitsi-bits, coz i went to u-steal it and got some calipers off of a 92 Galant.
And the pads are new 8O
oh and cost $44
Post Posted: Wed Nov 17, 2010 12:12 am
nice score, gotta love u=steal it... i'm guessing there was only the one down there?
Post Posted: Wed Nov 17, 2010 12:17 am
Unfortunetly yes only that one. I couldnt find a model number on the thing, i could find that it was a 92 but that was about it.
It was just a 2 wheel drive 2.0l model. Not the fancy simon mentioned.
Post Posted: Wed Nov 17, 2010 12:22 am
I checked out all the magna's 88-98 and they all run pbr's and all look alot bigger than these galant ones.
Post Posted: Wed Nov 17, 2010 5:53 am
the ones i saw at the old u-steal-it were on a vr4, they looked different to those ones
when are you ordering a kit? wanna go halves in postage? :wink:
Post Posted: Wed Nov 17, 2010 6:51 am
Ive fired off a pm to Ben, i'll be ordering it straight away.
We'll see what he says :wink:
Post Posted: Wed Nov 17, 2010 7:19 am
Yeah im cool with whenever. Have been meaning to do this for a while, but as usual, haven't got around to it yet! Now's as gooder time as any :)
Users browsing this forum: No registered users and 19 guests
